Skip Transcode on Sync (for Compatible Files)
I have a Nexus 7 2013 that is compatible with a lot of different media formats. So why do I always have to transcode when I want to Sync? If the file/media is compatible with the playback device, the file should just be copied instead of transcoded. Better quality and faster.
Please allow simple copy for Sync when the media/file is compatible with the playback device; skip the unnecessary transcode for better quality and speed.
Thanks!
+1 for this.
I would love to see a sync based on 1:1 copy option.
Have you tried setting to maximum sync quality, how big is the media your trying to sync?
,Ashley
+1
,Ashley
Yes, it makes no difference. The media varies, from 500 MB to 3 GB.
Some of you have +1 replied in this thread; per the rules please click the "Like This" button on the first post so that it counts. Replies don't necessarily count. :)
On my android if I set Highest Quality my mp4/aac (Which I have transcoded all my media to) files are just downloaded straight to my Android without any Transcoding and the exact size they are on my Plex Server.
So you must have something in the files Plex thinks Android will not be able to natively play.
You can do this now by editing the profiles that are included with Plex for the devices that you are trying to sync to. Now before you edit them realize that they create these profiles to maximize playability and they know what they are doing :)
Plex has this issue, on the local network with DLNA. Some devices like the PS3 can play some common media files, but they still get transcoded. The profiles might not be extensive or necessarily accurate, I don't expect the developers to have every possible device and computer combination.
