Slecting transcoder device
Server Version#:1.43.0.10492
Windows 11 Pro 10.0.26200 Build 26200
I have 2 NVIDIA Quattro RTX 4000 graphic cards, 1 for running my displays, 1 for transcoding. Both are showing in the transcoding device selection box. No mater which one I select, it is transcoding on the same card as my displays.
Work around. I switched my monitors to the other card. This is a bug that needs to be fixed.
This should be possible. This has come up beside. I can’t remember exactly but i think there is a windows settings that affects this.
