Server Version#: 1.23.3.4707
Player Version#: 1.33.0.2444-a220eae4
I’m seeing a whole load of SLOW QUERY errors in the PMS logs. Media is on unRAID array, Plex Metadata/DB/Config is on a dedicated SATA SSD, not unRAID cache drive. Using official Plex container.
Jun 28, 2021 14:36:12.934 [0x155133a6fb38] Warning — SLOW QUERY: It took 340.000000 ms to retrieve 20 items.
Jun 28, 2021 14:36:12.934 [0x155139418b38] Warning — SLOW QUERY: It took 260.000000 ms to retrieve 17 items.
Jun 28, 2021 14:36:12.938 [0x155133252b38] Warning — SLOW QUERY: It took 320.000000 ms to retrieve 20 items.
Jun 28, 2021 14:36:12.940 [0x155133a4cb38] Warning — SLOW QUERY: It took 210.000000 ms to retrieve 13 items.
Jun 28, 2021 14:36:12.948 [0x1551331efb38] Warning — SLOW QUERY: It took 270.000000 ms to retrieve 20 items.
Jun 28, 2021 14:36:13.012 [0x1551339d5b38] Warning — SLOW QUERY: It took 210.000000 ms to retrieve 22 items.
Jun 28, 2021 14:36:13.037 [0x1551334d3b38] Warning — SLOW QUERY: It took 260.000000 ms to retrieve 31 items.
Jun 28, 2021 14:36:13.126 [0x155133a4cb38] Warning — SLOW QUERY: It took 260.000000 ms to retrieve 49 items.
I have optimised DB and cleared bundles. I have used SQLite to export and reimport the DB as per Repair a corrupted database, even though the intergrity check came back OK.
I have this exact issue and everyday i am restarting my plex server multiple times as it gets stuck when updating metadata for movies over night and will not complete the task with out restarting multiple times
You can try using the Optimize Database. You can also try deleting the container and readding it. Just make sure to point it back to the same appdata location.
i have optimized the database, i have removed the container and re-added it and then just for good measure re-optimized the db again. We will see how this goes and whether things improve.
Been having the same issue as OP for easily over 2 weeks now. My media is on a Synology NAS (6.x, not the newer 7.0 DSM version) and made a post here which has my log files if it helps:
Just chiming in hoping the more of us complaining and the Plex dev team will take this problems seriously.
I’m trying to import my music library and Plex has been running for days now. I setup my library to only use local metadata and logs are full of slow queries.
If I use Airsonic/Madsonc it can scan my whole library in a little over an hour.
I’m seeing the same issue a lot: Slow Query took xxx. On top of this issue, I’m seeing that many of my remote connections will simply say: An error occurred while attempting to play this video. Please check your connection and try again This never happened before and it’s happening on Nvidia shield and firetv devices. This started happening about 1-2 weeks ago. I have tried to optimize the database, clean the bundles, empty trash.
