Smart playlist across libraries
Use case:
I have labels for topics that I apply in all my libraries
I would like to create a playlist with all the movies that have a given label across all my libraries
For smart playlists, currently it seems to only pull the movies that fit the label from the library I created the playlist from.
For regular playlists, it seems I can manually add the movies from several libraries
Ask: would it be possible to have a checkbox for smart playlist authorizing PLEX to go across libraries?
There’s already an existing feature suggestion asking for that functionality for both smart playlists and collections. You can comment/vote in that thread…
