I’d like to be able to add videos to a playlist that isn’t already in a playlist.
Right now its a lot of if title does not contain and I think I am maxing out the number of filters i can add.
Would be nice to be able to add a filter saying not already in a filter to cover most of them.
The issue with this: as soon as you add it into a playlist, it is in a playlist. Which then removes it from the playlist. Which then causes it to get added to the playlist again. Which then…
You speak the tru tru.
What if it was something along the lines of not in playlist X but have it work as actual ORs instead of creating a new line with each?
I would enjoy seeing a prompt it item is found in placelist (duplicate) give me option to cancel or overwrite. I currently have no way of knowing if i am adding an item to a playlist if it already exists? Or am I missing something. Thanks so much.
