[Solved] Home Screen Shutdown/Quit/Sleep submenu
This used to be available in Plex8, on the home screen there was a submenu for Shutdown/Sleep/Quit so I could choose each time what I wanted to do. Now there is only the option to either Shutdown, Sleep or Quit - I can only select 1.
Any change this can be brought back as a feature?
Cheers!
have you tried the latest Plex/HT Preview release?
Yes, I am running the latest. However, in the Skin Settings I can only choose 1 of the 3 in the Power menu, what I would like is the option to show all 3 on the home screen and be able to always choose 1 of the 3 without going into the settings if that makes sense.
hit c to bring up the context menu when on the main menu.
wow, I really had no idea that was in there.... thanks!
