Some issue for PMS to detect H264 video codec
Server Version#: PMS 1.18.9.2571 (on synology NAS DS415play)
Player Version#: Rasplex 1.8.1 / Xbox One App 2.51.1.70
Since a week approximately I experiencing issue with the detection of H264 video codec for some movies and I don’t know why. I cannot find the issue exactlty.
Here is the information linked to released movie :
General
Complete name                            : The.Way.Back.2020.1080p.Amazon.WebRip.H264.AC3.DD5.1.Will1869\The.Way.Back.2020.1080p.Amazon.WebRip.H264.AC3.DD5.1.Will1869.mp4
Format                                   : MPEG-4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/isom/avc1)
File size                                : 2.96 GiB
Duration                                 : 1 h 48 min
Overall bit rate                         : 3 906 kb/s
Movie name                               : The.Way.Back.2020.1080p.Amazon.WebRip.H264.AC3.DD5.1.Will1869
Encoded date                             : UTC 2020-03-24 17:11:26
Tagged date                              : UTC 2020-03-24 17:35:52
Writing application                      : DVDFab 11.0.4.2
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : Main@L4
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 4 frames
Format settings, GOP                     : M=1, N=12
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Source duration                          : 1 h 48 min
Bit rate                                 : 3 454 kb/s
Width                                    : 1 916 pixels
Height                                   : 800 pixels
Display aspect ratio                     : 2.40:1
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Standard                                 : Component
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.094
Stream size                              : 2.62 GiB (88%)
Source stream size                       : 2.62 GiB (88%)
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Menus                                    : 3
Codec configuration box                  : avcC
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : Dolby Digital
Codec ID                                 : ac-3
Bit rate mode                            : Constant
Bit rate                                 : 448 kb/s
Channel(s)                               : 6 channels
Channel layout                           : L R C LFE Ls Rs
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Compression mode                         : Lossy
Stream size                              : 347 MiB (11%)
Title                                    : English (ac3 5.1)
Language                                 : English
Service kind                             : Complete Main
Default                                  : Yes
Alternate group                          : 1
Menu
Codec ID                                 : text
Menu For                                 : 1
00:00:00.000                             : Chapter 1
00:09:38.744                             : Chapter 2
00:15:52.117                             : Chapter 3
00:24:43.148                             : Chapter 4
00:31:33.474                             : Chapter 5
00:37:53.229                             : Chapter 6
00:44:59.404                             : Chapter 7
00:54:13.750                             : Chapter 8
01:04:13.182                             : Chapter 9
01:09:04.473                             : Chapter 10
01:17:55.795                             : Chapter 11
01:27:55.520                             : Chapter 12
01:33:15.840                             : Chapter 13
01:42:37.734                             : Chapter 14
[center] [img]https://i.imgur.com/7h7RXAY.jpg[/img]
[size=5] The Way Back (2020) [/size]
[img]https://i.imgur.com/IIaC3xj.png[/img]
[b][size=2]
VIDEO
Format - MP4
Codec - H264
Resolution - 1916x800
Frame Rate - 23.98
Bit Rate - 3901 Kbps
File Size - 2.95 GB
Duration - 1hrs 48mins
AUDIO
Audio Codec - AC3
Sample Rate - 48Khz
Channels - 6
Channel Layout - Dolby Digital 5.1
Bit Rate - 447 Kbps
Language -  English
Subtitles - No
Source - Amazon WebRip FGT
Can you describe your problem in a little more detail? What do you mean by “issue with detection of H.264 video codec?” Is your media not playing?
Please also include the media information from Plex itself for one of the affected files:
See the part regarding XML Information.
Here the XML info :
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="1" librarySectionTitle="Films" librarySectionUUID="ba9e18ac-4f48-4f6e-b6b4-27661c40784e" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1585084234">
<Video ratingKey="168584" key="/library/metadata/168584" guid="com.plexapp.agents.themoviedb://529485?lang=fr" studio="Warner Bros. Pictures" type="movie" title="The Way Back" titleSort="Way Back" librarySectionTitle="Films" librarySectionID="1" librarySectionKey="/library/sections/1" summary="Une star du basketball a perdu sa femme et sa famille à cause de son addiction. Il a l'espoir de trouver sa salvation en devenant le coach d'une équipe de basketball d'un lycée qui ne compte aucune victoire à son actif." rating="6.3" year="2020" thumb="/library/metadata/168584/thumb/1585513358" art="/library/metadata/168584/art/1585513358" duration="4701884" originallyAvailableAt="2020-03-05" addedAt="1585511596" updatedAt="1585513358">
<Media id="312356" duration="4701884" bitrate="5402" audioChannels="6" audioCodec="eac3" container="ac3">
<Part accessible="1" exists="1" id="314069" key="/library/parts/314069/1585327731/file.mp4" duration="4701884" file="/volume1/video/film/The Way Back (2020) - 1080p - H264 AC3 DD5.1/The Way Back (2020) - 1080p.mp4" size="3175099292" container="ac3" deepAnalysisVersion="4" requiredBandwidths="2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,2147483647">
<Stream id="681531" streamType="2" selected="1" codec="eac3" index="0" channels="6" bitrate="5402" audioChannelLayout="5.1(side)" requiredBandwidths="2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,2147483647" samplingRate="44100" displayTitle="Inconnu (EAC3 5.1)"/>
</Part>
</Media>
<Genre id="23" filter="genre=23" tag="Drame"/>
<Director id="34014" filter="director=34014" tag="Gavin O'Connor"/>
<Writer id="71705" filter="writer=71705" tag="Brad Ingelsby"/>
<Producer id="4531" filter="producer=4531" tag="Jennifer Todd"/>
<Producer id="3765" filter="producer=3765" tag="Ben Affleck"/>
<Producer id="71743" filter="producer=71743" tag="Mark Ciardi"/>
<Producer id="71744" filter="producer=71744" tag="Gordon Gray"/>
<Producer id="71745" filter="producer=71745" tag="Gavin O'Connor"/>
<Producer id="71746" filter="producer=71746" tag="Ravi D. Mehta"/>
<Country id="28" filter="country=28" tag="USA"/>
<Role id="3596" filter="actor=3596" tag="Ben Affleck" role="Jack Cunningham" thumb="http://image.tmdb.org/t/p/original/7Zy12dUasr43oF8hyU5iBz5iOpO.jpg"/>
<Role id="71706" filter="actor=71706" tag="Al Madrigal" role="Dan" thumb="http://image.tmdb.org/t/p/original/l82MsWdkLosVtdPDpbGa4H4k6mn.jpg"/>
<Role id="2763" filter="actor=2763" tag="Janina Gavankar" role="Angela" thumb="http://image.tmdb.org/t/p/original/3lj5jZFvjjc4XD6pdykMdgyPREp.jpg"/>
<Role id="71707" filter="actor=71707" tag="Michaela Watkins" role="Beth" thumb="http://image.tmdb.org/t/p/original/qw8RqZ2fehR0ZlHWwyH9WFjc3Qh.jpg"/>
<Role id="71708" filter="actor=71708" tag="Brandon Wilson" role="Brandon" thumb="http://image.tmdb.org/t/p/original/9deGHwBMpPh3mzPzEp2MXsXsnXH.jpg"/>
<Role id="71709" filter="actor=71709" tag="Will Ropp" role="Kenny"/>
<Role id="71710" filter="actor=71710" tag="Fernando Luis Vega" role="Sam Garcia"/>
<Role id="71711" filter="actor=71711" tag="Charles Lott, Jr." role="Chubbs"/>
<Role id="71712" filter="actor=71712" tag="Melvin Gregg" role="Marcus Parrish" thumb="http://image.tmdb.org/t/p/original/jkmvezKh6owK2RLO0acw3kY4j6U.jpg"/>
<Role id="71713" filter="actor=71713" tag="Ben Irving" role="Bobby Freeze"/>
<Role id="71714" filter="actor=71714" tag="Jeremy Radin" role="Father Mark Whelan"/>
<Role id="71715" filter="actor=71715" tag="Da'Vinchi" role="Devon Childress"/>
<Role id="71716" filter="actor=71716" tag="Nico David" role="Ryan" thumb="http://image.tmdb.org/t/p/original/quB5tGFaWtyDoj3aKzfybrSXdq2.jpg"/>
<Role id="71717" filter="actor=71717" tag="Chris Bruno" role="Sal" thumb="http://image.tmdb.org/t/p/original/sZwn1Yo5DzcD6E8TiiEiDaPDUdw.jpg"/>
<Role id="1850" filter="actor=1850" tag="Glynn Turman" role="Doc" thumb="http://image.tmdb.org/t/p/original/yEW4JrFPyTTsoSeDQYwHxBihMuM.jpg"/>
<Role id="71718" filter="actor=71718" tag="T. K. Carter" role="Russ" thumb="http://image.tmdb.org/t/p/original/dWW4ZaZkH2Pt2xsZPTjTXoZPyMl.jpg"/>
<Role id="71719" filter="actor=71719" tag="Jeremy Ratchford" role="Matty" thumb="http://image.tmdb.org/t/p/original/fzzVrrOw00lWlqJs4dBSD8gJGZg.jpg"/>
<Role id="71720" filter="actor=71720" tag="Jayne Taini" role="Susan Norris" thumb="http://image.tmdb.org/t/p/original/h5LSieXoaaqafx5nNQWz1GAX0GP.jpg"/>
<Role id="71721" filter="actor=71721" tag="Sal Velez Jr." role="Miguel" thumb="http://image.tmdb.org/t/p/original/8Jlay4bwohlIZHTOvc4bymnXySW.jpg"/>
<Role id="71722" filter="actor=71722" tag="Yeniffer Behrens" role="Sofia" thumb="http://image.tmdb.org/t/p/original/sxc7FVhUYUgOg8KINil5Lf9PxgY.jpg"/>
<Role id="71723" filter="actor=71723" tag="Rachael Carpani" role="Diane" thumb="http://image.tmdb.org/t/p/original/kGbaThad5ozukGk1e4LBn8S2VjA.jpg"/>
<Role id="71724" filter="actor=71724" tag="Caleb Thomas" role="Mike Ball Boy" thumb="http://image.tmdb.org/t/p/original/6SR0EQdTji9rUWGuLX3lmtfc0jd.jpg"/>
<Role id="70061" filter="actor=70061" tag="Marlene Forte" role="Gale" thumb="http://image.tmdb.org/t/p/original/5TUmUz8kLeACwb56EVcLu1lyZR0.jpg"/>
<Role id="71725" filter="actor=71725" tag="Lukas Gage" role="Eddie" thumb="http://image.tmdb.org/t/p/original/2OpS8VhuHY6fV60iLQoaCUwK3rG.jpg"/>
<Role id="69184" filter="actor=69184" tag="Christine Horn" role="Doctor" thumb="http://image.tmdb.org/t/p/original/pjLRUglYTx9yVQ9gHSWbN8ET7to.jpg"/>
<Role id="71726" filter="actor=71726" tag="Edelyn Okano" role="Denise"/>
<Role id="67997" filter="actor=67997" tag="Jay Abdo" role="Liquor Store Owner" thumb="http://image.tmdb.org/t/p/original/dxnQROj7IK4NGonL9bYcilzUxWj.jpg"/>
<Role id="71727" filter="actor=71727" tag="Olivia Cannizzo" role="Cheerleader"/>
<Role id="64170" filter="actor=64170" tag="Christina Sergoyan" role="Cheerleader"/>
<Role id="71728" filter="actor=71728" tag="Tom Archdeacon" role="Ethan" thumb="http://image.tmdb.org/t/p/original/iIKMFjmHkUHso6Nx4yWB2UG3zK.jpg"/>
<Role id="71729" filter="actor=71729" tag="James P. Harkins" role="Burly Man"/>
<Role id="71730" filter="actor=71730" tag="Rylee Cravens" role="Hayes Student" thumb="http://image.tmdb.org/t/p/original/s5bWTdXHkXgXLoRYHMLqrQJAvJF.jpg"/>
<Role id="71731" filter="actor=71731" tag="Chieko Hidaka" role="Haley"/>
<Role id="71732" filter="actor=71732" tag="Mike G." role="Employee" thumb="http://image.tmdb.org/t/p/original/g4Vp1kQq6E05Czb1JNyIFbfVWO0.jpg"/>
<Role id="71733" filter="actor=71733" tag="Jedediah Jenk" role="Basketball Fan" thumb="http://image.tmdb.org/t/p/original/8PXojBz1JVcr0c4IJgLwq5rPiV4.jpg"/>
<Role id="71734" filter="actor=71734" tag="Troy Brookins" role="Memorial Basketball Player"/>
<Role id="71735" filter="actor=71735" tag="Josh Latzer" role="Construction Worker #1" thumb="http://image.tmdb.org/t/p/original/fevFmfIsmS8IWhOEnKquzGnLurI.jpg"/>
<Role id="71736" filter="actor=71736" tag="Shay Roundtree" role="Ken"/>
<Role id="71737" filter="actor=71737" tag="Cynthia Rose Hall" role="Nancy" thumb="http://image.tmdb.org/t/p/original/2smr3woZZli4Xd0bVjcLoDZSq8m.jpg"/>
<Role id="64148" filter="actor=64148" tag="Alexander Tassopoulos" role="Basketball Player"/>
<Role id="71738" filter="actor=71738" tag="Craig Reed" role="Bar Patron w / Truck"/>
<Role id="67838" filter="actor=67838" tag="Chad Mountain" role="Pat" thumb="http://image.tmdb.org/t/p/original/pRwVRxykn2YBA9YpLSbTb7awe5i.jpg"/>
<Role id="71739" filter="actor=71739" tag="Brian Nuesi" role="Basketball Player 7"/>
<Role id="71740" filter="actor=71740" tag="Carly Schneider" role="Cheerleader"/>
<Role id="64259" filter="actor=64259" tag="R.J. Asher" role="Bar Patron"/>
<Role id="71741" filter="actor=71741" tag="Shantiel Alexis Vazquez" role="Basketball Fan" thumb="http://image.tmdb.org/t/p/original/eQmd1AxjxKrS1X1pkpboumuZ3Ol.jpg"/>
<Role id="71742" filter="actor=71742" tag="Justice Alan" role="David"/>
<Extras size="0"> </Extras>
<Related>
<Hub hubKey="/library/metadata/13787" key="/library/metadata/168584/similar" title="Films reliés" type="movie" hubIdentifier="movie.similar" context="hub.movie.similar" size="1" more="1" style="shelf">
<Video ratingKey="13787" key="/library/metadata/13787" guid="com.plexapp.agents.themoviedb://210577?lang=fr" studio="20th Century Fox" type="movie" title="Gone girl" librarySectionTitle="Films" librarySectionID="1" librarySectionKey="/library/sections/1" originalTitle="Gone Girl" contentRating="fr/U" summary="Amy et Nick forment en apparence un couple modèle. Victimes de la crise, ils quittent Manhattan pour retourner s’installer dans la ville du Missouri où Nick a grandi. Mais le jour de leur 5ème anniversaire de mariage, Amy disparaît et Nick retrouve leur maison saccagée. Lors de l’enquête tout semble accuser Nick. Celui-ci décide, de son côté, de tout faire pour savoir ce qui est arrivé à Amy et découvre qu’elle lui dissimulait beaucoup de choses." rating="7.9" viewCount="1" lastViewedAt="1447188165" year="2014" tagline="Il ne faut pas se fier aux apparences..." thumb="/library/metadata/13787/thumb/1576136281" art="/library/metadata/13787/art/1576136281" duration="8941983" originallyAvailableAt="2014-10-08" addedAt="1419545153" updatedAt="1576136281" chapterSource="media">
<Media id="12615" duration="8941983" bitrate="11993" width="1920" height="800" aspectRatio="2.35" audioChannels="6" audioCodec="dca" videoCodec="h264" videoResolution="1080" container="mkv" videoFrameRate="24p" audioProfile="dts" videoProfile="high">
<Part id="285753" key="/library/parts/285753/1419265062/file.mkv" duration="8941983" file="/volume1/video/film/Gone Girl (2014) - 1080p/Gone Girl (2014) - 1080p.mkv" size="13408626316" audioProfile="dts" container="mkv" deepAnalysisVersion="4" requiredBandwidths="22668,17216,14635,13182,12705,12367,12247,12247" videoProfile="high">
<Stream id="603490" streamType="1" default="1" codec="h264" index="0" bitrate="10036" language="English" languageCode="eng" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" frameRate="23.976" hasScalingMatrix="0" height="800" level="41" profile="high" refFrames="5" requiredBandwidths="20709,15258,12677,11225,10747,10410,10292,10292" scanType="progressive" width="1920" displayTitle="1080p (H.264)"/>
<Stream id="603491" streamType="2" selected="1" codec="dca" index="1" channels="6" bitrate="1509" language="English" languageCode="eng" audioChannelLayout="5.1(side)" bitDepth="24" profile="dts" requiredBandwidths="1509,1509,1509,1509,1509,1509,1509,1509" samplingRate="48000" title="English" displayTitle="English (DTS 5.1)"/>
<Stream id="603492" streamType="2" default="1" forced="1" codec="ac3" index="2" channels="6" bitrate="448" language="Français" languageCode="fre" audioChannelLayout="5.1(side)" requiredBandwidths="448,448,448,448,448,448,448,448" samplingRate="48000" title="French" displayTitle="Français (AC3 5.1)"/>
<Stream id="603493" streamType="3" selected="1" default="1" forced="1" codec="srt" index="3" language="Français" languageCode="fre" requiredBandwidths="1,1,1,1,1,1,1,1" title="French Forced" displayTitle="Français Forcé(e) (SRT)"/>
<Stream id="603494" streamType="3" codec="srt" index="4" bitrate="0" language="Français" languageCode="fre" requiredBandwidths="1,1,1,1,1,1,1,1" title="French" displayTitle="Français (SRT)"/>
</Part>
</Media>
<Genre id="269" filter="genre=269" tag="Mystère"/>
<Genre id="147" filter="genre=147" tag="Thriller"/>
<Director id="1582" filter="director=1582" tag="David Fincher"/>
<Writer id="9139" filter="writer=9139" tag="Gillian Flynn"/>
<Producer id="2887" filter="producer=2887" tag="Arnon Milchan"/>
<Producer id="9147" filter="producer=9147" tag="Reese Witherspoon"/>
<Producer id="8588" filter="producer=8588" tag="Ceán Chaffin"/>
<Producer id="23527" filter="producer=23527" tag="Joshua Donen"/>
<Role id="3596" filter="actor=3596" tag="Ben Affleck" role="Nick Dunne" thumb="http://image.tmdb.org/t/p/original/7Zy12dUasr43oF8hyU5iBz5iOpO.jpg"/>
<Role id="5802" filter="actor=5802" tag="Rosamund Pike" role="Amy Elliott Dunne" thumb="http://image.tmdb.org/t/p/original/8ObNklHDi2hjdz0ayzJFB9jtqzm.jpg"/>
<Role id="6991" filter="actor=6991" tag="Neil Patrick Harris" role="Desi Collins" thumb="http://image.tmdb.org/t/p/original/oyy0Enz4ZX8KYRYihgSgOA18Xc.jpg"/>
<Role id="5167" filter="actor=5167" tag="Tyler Perry" role="Tanner Bolt" thumb="http://image.tmdb.org/t/p/original/fdBvkrv4lSKZ97eDLpmjlK1Tnbx.jpg"/>
<Role id="1828" filter="actor=1828" tag="Carrie ■■■■" role="Margo Dunne" thumb="http://image.tmdb.org/t/p/original/aX7kfLrSYWK7s9KvjldO1JYCbPv.jpg"/>
<Role id="9142" filter="actor=9142" tag="Kim Dickens" role="Detective Rhonda Boney" thumb="http://image.tmdb.org/t/p/original/eaJky5Q6X51u0bnQkXyOrM8RnlG.jpg"/>
<Role id="9141" filter="actor=9141" tag="Patrick Fugit" role="Detective Jim Gilpin" thumb="http://image.tmdb.org/t/p/original/37RM0m1mDJ4YxC3n7QgwpXSUpkp.jpg"/>
<Role id="23479" filter="actor=23479" tag="David Clennon" role="Rand Elliott" thumb="http://image.tmdb.org/t/p/original/sUZ6eL77Eh0aNYSx2NaB9NEZeCf.jpg"/>
<Role id="23480" filter="actor=23480" tag="Lisa Banes" role="Marybeth Elliott" thumb="http://image.tmdb.org/t/p/original/rXBe8lx88ESRIoKLqUMIYWpfoCq.jpg"/>
<Role id="9140" filter="actor=9140" tag="Missi Pyle" role="Ellen Abbott" thumb="http://image.tmdb.org/t/p/original/gjJiT50eCgPMRsIKl03v64CJOPf.jpg"/>
<Role id="9145" filter="actor=9145" tag="Emily Ratajkowski" role="Andie Fitzgerald" thumb="http://image.tmdb.org/t/p/original/f4BrGsuqzcjEdb0GfWvZuG4vqJo.jpg"/>
<Role id="9143" filter="actor=9143" tag="Casey Wilson" role="Noelle Hawthorne" thumb="http://image.tmdb.org/t/p/original/pS81iG4Dt64I8ibh3teGzigi3eu.jpg"/>
<Role id="9146" filter="actor=9146" tag="Lola Kirke" role="Greta" thumb="http://image.tmdb.org/t/p/original/xXEBb9OoET7SgtkSmh1XtMs5YKC.jpg"/>
<Role id="4719" filter="actor=4719" tag="Boyd Holbrook" role="Jeff" thumb="http://image.tmdb.org/t/p/original/531YOKa2usleWCA55t6Db4MZhT3.jpg"/>
<Role id="253" filter="actor=253" tag="Scoot McNairy" role="Tommy O'Hara" thumb="http://image.tmdb.org/t/p/original/7Z05H1bdSGCHWLImOSxaDVJIQ7z.jpg"/>
<Role id="23477" filter="actor=23477" tag="Sela Ward" role="Sharon Schieber" thumb="http://image.tmdb.org/t/p/original/3uSTaQgaU7HI1HG2ZPwfflVfGZv.jpg"/>
<Role id="23478" filter="actor=23478" tag="Lee Norris" role="Police Officer" thumb="http://image.tmdb.org/t/p/original/sE16s5VE42RuTJvRZA5wuDzTDYB.jpg"/>
<Role id="3194" filter="actor=3194" tag="Jamie McShane" role="Donnelly" thumb="http://image.tmdb.org/t/p/original/clBmHn1I4WzawHYm5jGPfX44ysp.jpg"/>
<Role id="23481" filter="actor=23481" tag="Leonard Kelly-Young" role="Bill Dunne" thumb="http://image.tmdb.org/t/p/original/m6FeP3hJl5Dkbou9YYh2TOg3W9p.jpg"/>
<Role id="9144" filter="actor=9144" tag="Kathleen Rose Perkins" role="Shawna Kelly" thumb="http://image.tmdb.org/t/p/original/1BGldxkKa8p5xPG105QNSVrF4hg.jpg"/>
<Role id="23482" filter="actor=23482" tag="Pete Housman" role="Walter" thumb="http://image.tmdb.org/t/p/original/9mov1X4C7KescyDcaQm1NqNIuPb.jpg"/>
<Role id="66150" filter="actor=66150" tag="Lynn Adrianna" role="Kelly Capitono" thumb="http://image.tmdb.org/t/p/original/1p5K0J4SEnGoD9haqk0KqLxL5S1.jpg"/>
<Role id="23493" filter="actor=23493" tag="Cyd Strittmatter" role="Maureen Dunne" thumb="http://image.tmdb.org/t/p/original/2o9gT6QOJ94KFhqWvzQiUkU2H9X.jpg"/>
<Role id="23499" filter="actor=23499" tag="Ricky Wood" role="Jason" thumb="http://image.tmdb.org/t/p/original/xNo1lBz1tguwv9NV451MGf1UWb3.jpg"/>
<Role id="23502" filter="actor=23502" tag="Donna Rusch" role="Lauren Nevens" thumb="http://image.tmdb.org/t/p/original/wpr3PoPDPuiTfFktzK42lOKJByZ.jpg"/>
<Role id="23484" filter="actor=23484" tag="Mark Atteberry" role="FBI" thumb="http://image.tmdb.org/t/p/original/nFHzunT4sOFOyi0pH2TGjDFTqSg.jpg"/>
<Role id="23485" filter="actor=23485" tag="Darin Cooper" role="Mustached Man" thumb="http://image.tmdb.org/t/p/original/ewACr0jcusD6d3psRFpVdjAq4La.jpg"/>
<Role id="23486" filter="actor=23486" tag="Kate Campbell" role="Above-It-All Journalist" thumb="http://image.tmdb.org/t/p/original/pDQwNRcXhquim1MmPf9INU3zjqR.jpg"/>
<Role id="23487" filter="actor=23487" tag="Brett Leigh" role="Nervous Intern" thumb="http://image.tmdb.org/t/p/original/nl4eus0kRy4L1i6uma88zDpS9uZ.jpg"/>
<Role id="23488" filter="actor=23488" tag="Antonio St. James" role="Security Guard" thumb="http://image.tmdb.org/t/p/original/nzzozryKaKgEe2FYm3iFOUJr5nF.jpg"/>
<Role id="23489" filter="actor=23489" tag="Lauren Glazier" role="Fashionista" thumb="http://image.tmdb.org/t/p/original/bvpmxumWqD9K5MoNzGtEvavlQXu.jpg"/>
<Role id="23490" filter="actor=23490" tag="Julia Prud'homme" role="Female Officer" thumb="http://image.tmdb.org/t/p/original/4t39UeNsXOVq5hlcuYAFXin9eCX.jpg"/>
<Role id="23491" filter="actor=23491" tag="Cooper Thornton" role="Doctor" thumb="http://image.tmdb.org/t/p/original/A0rZn1YC69t2iRcBmyqbQNeiof2.jpg"/>
<Role id="23492" filter="actor=23492" tag="Casey Ruggieri" role="Earnest Girl" thumb="http://image.tmdb.org/t/p/original/cbiC792SXkzeW6fWt4j0FCdUY7h.jpg"/>
<Role id="23494" filter="actor=23494" tag="Ashley Didion" role="Friend 1" thumb="http://image.tmdb.org/t/p/original/uklcsbamATGDeRInYmmun7Zcuuq.jpg"/>
<Role id="23495" filter="actor=23495" tag="Lexis Nutt" role="Friend 2" thumb="http://image.tmdb.org/t/p/original/wcY6qyOzHyHWNOtR7dQFvdHcrbZ.jpg"/>
<Role id="23496" filter="actor=23496" tag="L.A. Williams" role="Guard" thumb="http://image.tmdb.org/t/p/original/3GfO8WCTcKtczysg4w1N3tPAjRL.jpg"/>
<Role id="23497" filter="actor=23497" tag="Blake Sheldon" role="Tweaker Teen 1" thumb="http://image.tmdb.org/t/p/original/vsO5FeqEilC9AgNwIOkpgOd4XEd.jpg"/>
<Role id="23498" filter="actor=23498" tag="Sean Guse" role="Tweaker Teen 2" thumb="http://image.tmdb.org/t/p/original/qAnjjbWMexiRUsQFFGF9I5spAU0.jpg"/>
<Role id="23500" filter="actor=23500" tag="Fred Cross" role="Airport Traveler" thumb="http://image.tmdb.org/t/p/original/8IVRSHVKBvXTE8JNt20JyKAwZyM.jpg"/>
<Role id="23501" filter="actor=23501" tag="Scott Takeda" role="Producer" thumb="http://image.tmdb.org/t/p/original/boNzT15JQ92aKHkHJkLc4Cwx5p0.jpg"/>
<Role id="23504" filter="actor=23504" tag="Mark T Anderson" role="Reporter" thumb="http://image.tmdb.org/t/p/original/iswbwgE5Gv3uRftrOSypwz6Dyqr.jpg"/>
<Role id="23503" filter="actor=23503" tag="Kathy Sweeney-Meadows" role="Reporter One"/>
<Role id="23505" filter="actor=23505" tag="Marc Abbink" role="Casino Patron (uncredited)" thumb="http://image.tmdb.org/t/p/original/wxShQ6tTyTWNJguDU4WIdeSeww5.jpg"/>
<Role id="23506" filter="actor=23506" tag="Christina Alex" role="Airport Passenger (uncredited)"/>
<Role id="23507" filter="actor=23507" tag="Samuel Baca" role="Casino Customer (uncredited)" thumb="http://image.tmdb.org/t/p/original/qqaVlPeXvZEXfTPfWsyoefAoLhn.jpg"/>
<Role id="23508" filter="actor=23508" tag="Bill Blair" role="Press Reporter (uncredited)" thumb="http://image.tmdb.org/t/p/original/4KOzgrH3foqk5NBbfWFtNKsfGUf.jpg"/>
<Role id="23509" filter="actor=23509" tag="Thomas R. Baker" role="Limo Driver (uncredited)" thumb="http://image.tmdb.org/t/p/original/mfVU6sGHzPcaCOnVhwyDkeMqKOs.jpg"/>
<Role id="23510" filter="actor=23510" tag="Gregoer Boru" role="Needs a Fix (uncredited)" thumb="http://image.tmdb.org/t/p/original/7lAE72WXLibZ6cfN7PRrXB0fEgv.jpg"/>
<Role id="23511" filter="actor=23511" tag="Will C." role="Black Jack Dealer (uncredited)" thumb="http://image.tmdb.org/t/p/original/7za9xUGfIy0Ho3CJoD7KP4KPcFT.jpg"/>
<Role id="23512" filter="actor=23512" tag="Caroline Clements" role="Waitress (uncredited)" thumb="http://image.tmdb.org/t/p/original/89rK4urc9U5ybDfNQY30o00uAbS.jpg"/>
<Role id="23513" filter="actor=23513" tag="Nancy DeMars" role="Flight Attendant (uncredited)" thumb="http://image.tmdb.org/t/p/original/o5iL2oiIqfcaHvEkXWjpHIwpfTG.jpg"/>
<Role id="23514" filter="actor=23514" tag="Davina Joy" role="Reporter (uncredited)" thumb="http://image.tmdb.org/t/p/original/lT4kefEBFHZjLZyDd4lqZHC9xSx.jpg"/>
<Role id="1649" filter="actor=1649" tag="Michael Kelly" role="CSI Photographer (uncredited)" thumb="http://image.tmdb.org/t/p/original/iivECyPFmK7SeT3iBtmOgz3n3M7.jpg"/>
<Role id="23515" filter="actor=23515" tag="Elester Latham" role="High Roll Dealer (uncredited)" thumb="http://image.tmdb.org/t/p/original/1IlxOuvptLb7pH2j0t1KLQukzdG.jpg"/>
<Role id="23516" filter="actor=23516" tag="Aaron Massey" role="Sharon's Assistant (uncredited)" thumb="http://image.tmdb.org/t/p/original/y9C8aAImPDFEapxfVmNNYLwWjJ8.jpg"/>
<Role id="23517" filter="actor=23517" tag="Orion McCabe" role="Coffee Cop (uncredited)" thumb="http://image.tmdb.org/t/p/original/o43G6iYRiZzou7RUxdoEQn6O18y.jpg"/>
<Role id="23518" filter="actor=23518" tag="Roz McHenry" role="Hostess (uncredited)" thumb="http://image.tmdb.org/t/p/original/rjvlqkLhDcstwScpukRHqpzfxKP.jpg"/>
<Role id="23519" filter="actor=23519" tag="Bryan McKinley" role="Truck Stop Cook (uncredited)" thumb="http://image.tmdb.org/t/p/original/5CyRIhz8LyaNJBBq0AL34UuZWPk.jpg"/>
<Role id="10205" filter="actor=10205" tag="Teebone Mitchell" role="Dealer (uncredited)" thumb="http://image.tmdb.org/t/p/original/dplhzHkATBtyUeaAo7T2aHbaGA.jpg"/>
<Role id="23520" filter="actor=23520" tag="Justin Nesbitt" role="Amish Musician (uncredited)" thumb="http://image.tmdb.org/t/p/original/6xkISBqCGVzFy7nlHl0ZV6cEsJX.jpg"/>
<Role id="23521" filter="actor=23521" tag="Mark Parrish" role="Bartender (uncredited)" thumb="http://image.tmdb.org/t/p/original/bwmwvqF2Di9LvD4tpBdpNqyrPi4.jpg"/>
<Role id="23522" filter="actor=23522" tag="Jaclyn Rose" role="Pedestrian (uncredited)" thumb="http://image.tmdb.org/t/p/original/evh7mXdb8j9kVBqmYJcPSjznzt0.jpg"/>
<Role id="23523" filter="actor=23523" tag="Sahlima" role="Gate Agent (uncredited)" thumb="http://image.tmdb.org/t/p/original/ghP8i5zNAyWRQEbnp4QqJnEppjk.jpg"/>
<Role id="23524" filter="actor=23524" tag="Joel Shock" role="Bike Messenger (uncredited)" thumb="http://image.tmdb.org/t/p/original/q1dCgFesKImOzvp1sd2zQ1hu5WG.jpg"/>
<Role id="23525" filter="actor=23525" tag="Robert Tarpinian" role="Williamsburg Musician (uncredited)"/>
<Role id="23526" filter="actor=23526" tag="Tracy Weisert" role="Police Station Woman (uncredited)" thumb="http://image.tmdb.org/t/p/original/5TWjcFCFceYR29HCi6VokKc8c5O.jpg"/>
<Role id="66152" filter="actor=66152" tag="Michelle Winters" role="Makeup (uncredited)" thumb="http://image.tmdb.org/t/p/original/mKmUgBEA34zIzCWirUk75xJzFU5.jpg"/>
<Role id="58038" filter="actor=58038" tag="Tracy Brotherton" role="Press Reporter (uncredited)" thumb="http://image.tmdb.org/t/p/original/fHaAqoPxZ3s1UX8FMxwb2bs0Aqz.jpg"/>
<Role id="66151" filter="actor=66151" tag="Matilde Matteucci" role="Kissing Girl (uncredited)" thumb="http://image.tmdb.org/t/p/original/wLD3kOzfWT4lwUj4VlxHOq6W9bk.jpg"/>
<Role id="66148" filter="actor=66148" tag="Dale Shane" role="Librarian (uncredited)" thumb="http://image.tmdb.org/t/p/original/y3eIN7e2VnlgDBYlJpGQT99jyHd.jpg"/>
<Role id="66149" filter="actor=66149" tag="Leslie A. Hughes" role="Police Administrator (uncredited)" thumb="http://image.tmdb.org/t/p/original/ihhstLzFqzYCICREPSEvSJvW5NF.jpg"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="1" startTimeOffset="0" endTimeOffset="207957" thumb="/library/media/12615/chapterImages/1"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="2" startTimeOffset="207957" endTimeOffset="417834" thumb="/library/media/12615/chapterImages/2"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="3" startTimeOffset="417834" endTimeOffset="499540" thumb="/library/media/12615/chapterImages/3"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="4" startTimeOffset="499540" endTimeOffset="718592" thumb="/library/media/12615/chapterImages/4"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="5" startTimeOffset="718592" endTimeOffset="901484" thumb="/library/media/12615/chapterImages/5"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="6" startTimeOffset="901484" endTimeOffset="1093509" thumb="/library/media/12615/chapterImages/6"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="7" startTimeOffset="1093509" endTimeOffset="1196737" thumb="/library/media/12615/chapterImages/7"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="8" startTimeOffset="1196737" endTimeOffset="1303093" thumb="/library/media/12615/chapterImages/8"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="9" startTimeOffset="1303093" endTimeOffset="1433848" thumb="/library/media/12615/chapterImages/9"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="10" startTimeOffset="1433848" endTimeOffset="1714880" thumb="/library/media/12615/chapterImages/10"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="11" startTimeOffset="1714880" endTimeOffset="1892516" thumb="/library/media/12615/chapterImages/11"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="12" startTimeOffset="1892516" endTimeOffset="2079077" thumb="/library/media/12615/chapterImages/12"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="13" startTimeOffset="2079077" endTimeOffset="2451199" thumb="/library/media/12615/chapterImages/13"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="14" startTimeOffset="2451199" endTimeOffset="2677382" thumb="/library/media/12615/chapterImages/14"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="15" startTimeOffset="2677382" endTimeOffset="2817815" thumb="/library/media/12615/chapterImages/15"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="16" startTimeOffset="2817815" endTimeOffset="2959706" thumb="/library/media/12615/chapterImages/16"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="17" startTimeOffset="2959706" endTimeOffset="3253333" thumb="/library/media/12615/chapterImages/17"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="18" startTimeOffset="3253333" endTimeOffset="3606686" thumb="/library/media/12615/chapterImages/18"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="19" startTimeOffset="3606686" endTimeOffset="3796208" thumb="/library/media/12615/chapterImages/19"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="20" startTimeOffset="3796208" endTimeOffset="3968715" thumb="/library/media/12615/chapterImages/20"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="21" startTimeOffset="3968715" endTimeOffset="4376997" thumb="/library/media/12615/chapterImages/21"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="22" startTimeOffset="4376997" endTimeOffset="4513007" thumb="/library/media/12615/chapterImages/22"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="23" startTimeOffset="4513007" endTimeOffset="4794456" thumb="/library/media/12615/chapterImages/23"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="24" startTimeOffset="4794456" endTimeOffset="4916119" thumb="/library/media/12615/chapterImages/24"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="25" startTimeOffset="4916119" endTimeOffset="5244155" thumb="/library/media/12615/chapterImages/25"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="26" startTimeOffset="5244155" endTimeOffset="5292537" thumb="/library/media/12615/chapterImages/26"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="27" startTimeOffset="5292537" endTimeOffset="5608560" thumb="/library/media/12615/chapterImages/27"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="28" startTimeOffset="5608560" endTimeOffset="5974510" thumb="/library/media/12615/chapterImages/28"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="29" startTimeOffset="5974510" endTimeOffset="6386713" thumb="/library/media/12615/chapterImages/29"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="30" startTimeOffset="6386713" endTimeOffset="6646515" thumb="/library/media/12615/chapterImages/30"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="31" startTimeOffset="6646515" endTimeOffset="7000618" thumb="/library/media/12615/chapterImages/31"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="32" startTimeOffset="7000618" endTimeOffset="7146096" thumb="/library/media/12615/chapterImages/32"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="33" startTimeOffset="7146096" endTimeOffset="7343127" thumb="/library/media/12615/chapterImages/33"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="34" startTimeOffset="7343127" endTimeOffset="7535069" thumb="/library/media/12615/chapterImages/34"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="35" startTimeOffset="7535069" endTimeOffset="7950818" thumb="/library/media/12615/chapterImages/35"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="36" startTimeOffset="7950818" endTimeOffset="8172789" thumb="/library/media/12615/chapterImages/36"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="37" startTimeOffset="8172789" endTimeOffset="8396930" thumb="/library/media/12615/chapterImages/37"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="38" startTimeOffset="8396930" endTimeOffset="8562304" thumb="/library/media/12615/chapterImages/38"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="39" startTimeOffset="8562304" endTimeOffset="8655647" thumb="/library/media/12615/chapterImages/39"/>
<Chapter id="8328" filter="thumb=8328" tag="" index="40" startTimeOffset="8655647" endTimeOffset="8941984" thumb="/library/media/12615/chapterImages/40"/>
</Video>
</Hub>
<Hub hubKey="/library/metadata/32914" key="/library/sections/1/all?actor=3596&id!=168584" title="Plus avec Ben Affleck" type="movie" hubIdentifier="movie.same.actor.0" context="hub.movie.same.actor" size="1" more="1" style="shelf">
<Video ratingKey="32914" key="/library/metadata/32914" guid="com.plexapp.agents.themoviedb://68734?lang=fr" studio="Warner Bros. Pictures" type="movie" title="Argo" contentRating="fr/U" summary="Le 4 novembre 1979, au summum de la révolution iranienne, des militants envahissent l’ambassade américaine de Téhéran, et prennent 52 Américains en otage. Mais au milieu du chaos, six Américains réussissent à s’échapper et à se réfugier au domicile de l’ambassadeur canadien. Sachant qu’ils seront inévitablement découverts et probablement tués, un spécialiste de "l’exfiltration" de la CIA du nom de Tony Mendez monte un plan risqué visant à les faire sortir du pays. Un plan si incroyable qu’il ne pourrait exister qu’au cinéma." rating="7.2" year="2012" tagline="Le film était faux. La mission bien réelle." thumb="/library/metadata/32914/thumb/1576135892" art="/library/metadata/32914/art/1576135892" duration="7223235" originallyAvailableAt="2012-11-05" addedAt="1450528937" updatedAt="1576135892" chapterSource="media">
<Media id="40437" duration="7223235" bitrate="16671" width="1920" height="800" aspectRatio="2.35" audioChannels="6" audioCodec="vorbis" videoCodec="h264" videoResolution="1080" container="mkv" videoFrameRate="24p" videoProfile="high 10">
<Part id="285878" key="/library/parts/285878/1448204774/file.mkv" duration="7223235" file="/volume1/video/film/Argo (2012) - 1080p/Argo (2012) - 1080p.mkv" size="15021389833" container="mkv" deepAnalysisVersion="4" hasThumbnail="1" requiredBandwidths="2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,2147483647,2147483647" videoProfile="high 10"/>
</Media>
<Genre tag="Drame"/>
<Genre tag="Thriller"/>
<Director tag="Ben Affleck"/>
<Writer tag="Chris Terrio"/>
<Country tag="USA"/>
<Role tag="Adrienne Barbeau"/>
<Role tag="Aidan Sussman"/>
<Role tag="Alan Arkin"/>
</Video>
</Hub>
</Related>
</Video>
</MediaContainer>
