player could not render this content media might be corrupt or the mediatype is not supported
anyone know what the hell I get this on several of Samsung TVs that I have? .. 3 televisions I have in a house on 1 looks perfectly and the remaining 2 I get the happy message when trying to play any movie, use clound sync, google drive storage and I plex pass, that in me and leave the other 2 not? They are updated to the last firm from home, and one is from last Llas that Samsung released the model 4k, see if someone enlightens me.
Please provide the log files and media XML.
log file and media XML,thanks…^^
and media XML, ^^
Looking at the Deep Analysis logs, “Plex Media Scanner Deep Analysis.2.log”
D:\Peliculas en HD\Election La noche de las bestias.mkv is the fault.
Oct 28, 2016 02:03:49.582 [7032] DEBUG - [MI] Opening input file: D:\Peliculas en HD\Election La noche de las bestias.mkv
Oct 28, 2016 02:03:49.582 [7032] DEBUG - [FFMPEG] - Setting default whitelist 'file,crypto'
Oct 28, 2016 02:03:49.583 [7032] DEBUG - [FFMPEG] - Format matroska,webm probed with size=2048 and score=100
Oct 28, 2016 02:03:49.585 [7032] DEBUG - [FFMPEG] - st:0 removing common factor 1000000 from timebase
Oct 28, 2016 02:03:49.585 [7032] DEBUG - [FFMPEG] - st:1 removing common factor 1000000 from timebase
Oct 28, 2016 02:03:49.585 [7032] DEBUG - [FFMPEG] - st:2 removing common factor 1000000 from timebase
Oct 28, 2016 02:03:49.585 [7032] DEBUG - [FFMPEG] - st:3 removing common factor 1000000 from timebase
Oct 28, 2016 02:03:49.585 [7032] DEBUG - [FFMPEG] - st:4 removing common factor 1000000 from timebase
Oct 28, 2016 02:03:49.585 [7032] DEBUG - [FFMPEG] - st:5 removing common factor 1000000 from timebase
Oct 28, 2016 02:03:49.585 [7032] DEBUG - [FFMPEG] - Before avformat_find_stream_info() pos: 7233 bytes read:32768 seeks:0
Oct 28, 2016 02:03:49.589 [7032] DEBUG - [FFMPEG] - nal_unit_type: 7, nal_ref_idc: 3
Oct 28, 2016 02:03:49.589 [7032] DEBUG - [FFMPEG] - nal_unit_type: 8, nal_ref_idc: 3
Oct 28, 2016 02:03:49.595 [7032] DEBUG - [FFMPEG] - nal_unit_type: 7, nal_ref_idc: 3
Oct 28, 2016 02:03:49.596 [7032] DEBUG - [FFMPEG] - nal_unit_type: 8, nal_ref_idc: 3
Oct 28, 2016 02:03:49.597 [7032] DEBUG - [FFMPEG] - user data:"x264 - core 142 r2479 dd79a61 - H.264/MPEG-4 AVC codec - Copyleft 2003-2014 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:-3:-3 analyse=0x3:0x113 me=hex subme=2 psy=1 psy_rd=1.00:0.15 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=12 lookahead_threads=4 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=240 keyint_min=24 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=2pass mbtree=1 bitrate=2800 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 cplxblur=20.0 qblur=0.5 vbv_maxrate=62500 vbv_bufsize=78125 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00"
Oct 28, 2016 02:03:49.597 [7032] DEBUG - [FFMPEG] - nal_unit_type: 6, nal_ref_idc: 0
Oct 28, 2016 02:03:49.597 [7032] DEBUG - [FFMPEG] - nal_unit_type: 5, nal_ref_idc: 3
Oct 28, 2016 02:03:49.600 [7032] DEBUG - [FFMPEG] - no picture
Oct 28, 2016 02:03:49.604 [7032] DEBUG - [FFMPEG] - nal_unit_type: 1, nal_ref_idc: 2
Oct 28, 2016 02:03:49.606 [7032] DEBUG - [FFMPEG] - no picture
Oct 28, 2016 02:03:49.607 [7032] DEBUG - [FFMPEG] - nal_unit_type: 1, nal_ref_idc: 2
Oct 28, 2016 02:03:49.610 [7032] DEBUG - [FFMPEG] - nal_unit_type: 1, nal_ref_idc: 2
Oct 28, 2016 02:03:49.613 [7032] DEBUG - [FFMPEG] - nal_unit_type: 1, nal_ref_idc: 2
Oct 28, 2016 02:03:49.618 [7032] DEBUG - [FFMPEG] - nal_unit_type: 1, nal_ref_idc: 2
Oct 28, 2016 02:03:49.619 [7032] DEBUG - [FFMPEG] - nal_unit_type: 1, nal_ref_idc: 2
Oct 28, 2016 02:03:49.620 [7032] DEBUG - [FFMPEG] - nal_unit_type: 1, nal_ref_idc: 2
Oct 28, 2016 02:03:49.621 [7032] DEBUG - [FFMPEG] - nal_unit_type: 1, nal_ref_idc: 0
Oct 28, 2016 02:03:49.622 [7032] DEBUG - [FFMPEG] - All info found
Oct 28, 2016 02:03:49.622 [7032] DEBUG - [FFMPEG] - After avformat_find_stream_info() pos: 79882 bytes read:98304 seeks:0 frames:48
Oct 28, 2016 02:03:49.904 [7032] DEBUG - Deep Analysis: Read 10000 packets at 115.407000
Oct 28, 2016 02:03:50.207 [7032] DEBUG - Deep Analysis: Read 20000 packets at 230.592000
Oct 28, 2016 02:03:50.432 [7032] DEBUG - Deep Analysis: Read 30000 packets at 345.600000
Oct 28, 2016 02:03:50.586 [7032] DEBUG - Deep Analysis: Read 40000 packets at 460.416000
Oct 28, 2016 02:03:50.680 [7032] DEBUG - Deep Analysis: Read 50000 packets at 575.008000
Oct 28, 2016 02:03:50.771 [7032] DEBUG - Deep Analysis: Read 60000 packets at 689.792000
Oct 28, 2016 02:03:50.858 [7032] DEBUG - Deep Analysis: Read 70000 packets at 804.640000
Oct 28, 2016 02:03:50.936 [7032] DEBUG - Deep Analysis: Read 80000 packets at 919.424000
Oct 28, 2016 02:03:51.017 [7032] DEBUG - Deep Analysis: Read 90000 packets at 1034.336000
Oct 28, 2016 02:03:51.087 [7032] DEBUG - Deep Analysis: Read 100000 packets at 1149.664000
Oct 28, 2016 02:03:51.157 [7032] DEBUG - Deep Analysis: Read 110000 packets at 1264.672000
Oct 28, 2016 02:03:51.237 [7032] DEBUG - Deep Analysis: Read 120000 packets at 1379.776000
Oct 28, 2016 02:03:51.322 [7032] DEBUG - Deep Analysis: Read 130000 packets at 1494.912000
Oct 28, 2016 02:03:51.415 [7032] DEBUG - Deep Analysis: Read 140000 packets at 1610.080000
Oct 28, 2016 02:03:51.504 [7032] DEBUG - Deep Analysis: Read 150000 packets at 1725.472000
Oct 28, 2016 02:03:51.562 [7032] DEBUG - Deep Analysis: Read 160000 packets at 1840.928000
Oct 28, 2016 02:03:51.636 [7032] DEBUG - Deep Analysis: Read 170000 packets at 1956.192000
Oct 28, 2016 02:03:51.717 [7032] DEBUG - Deep Analysis: Read 180000 packets at 2071.488000
Oct 28, 2016 02:03:51.788 [7032] DEBUG - Deep Analysis: Read 190000 packets at 2186.517000
Oct 28, 2016 02:03:51.861 [7032] DEBUG - Deep Analysis: Read 200000 packets at 2301.760000
Oct 28, 2016 02:03:51.946 [7032] DEBUG - Deep Analysis: Read 210000 packets at 2416.622000
Oct 28, 2016 02:03:52.030 [7032] DEBUG - Deep Analysis: Read 220000 packets at 2532.320000
Oct 28, 2016 02:03:52.122 [7032] DEBUG - Deep Analysis: Read 230000 packets at 2647.603000
Oct 28, 2016 02:03:52.201 [7032] DEBUG - Deep Analysis: Read 240000 packets at 2762.624000
Oct 28, 2016 02:03:52.285 [7032] DEBUG - Deep Analysis: Read 250000 packets at 2876.999000
Oct 28, 2016 02:03:52.367 [7032] DEBUG - Deep Analysis: Read 260000 packets at 2991.776000
Oct 28, 2016 02:03:52.455 [7032] DEBUG - Deep Analysis: Read 270000 packets at 3106.853000
Oct 28, 2016 02:03:52.535 [7032] DEBUG - Deep Analysis: Read 280000 packets at 3222.240000
Oct 28, 2016 02:03:52.605 [7032] DEBUG - Deep Analysis: Read 290000 packets at 3337.248000
Oct 28, 2016 02:03:52.682 [7032] DEBUG - Deep Analysis: Read 300000 packets at 3452.192000
Oct 28, 2016 02:03:52.759 [7032] DEBUG - Deep Analysis: Read 310000 packets at 3567.328000
Oct 28, 2016 02:03:52.848 [7032] DEBUG - Deep Analysis: Read 320000 packets at 3682.432000
Oct 28, 2016 02:03:52.929 [7032] DEBUG - Deep Analysis: Read 330000 packets at 3797.696000
Oct 28, 2016 02:03:53.013 [7032] DEBUG - Deep Analysis: Read 340000 packets at 3912.704000
Oct 28, 2016 02:03:53.090 [7032] DEBUG - Deep Analysis: Read 350000 packets at 4027.872000
Oct 28, 2016 02:03:53.161 [7032] DEBUG - Deep Analysis: Read 360000 packets at 4143.055000
Oct 28, 2016 02:03:53.237 [7032] DEBUG - Deep Analysis: Read 370000 packets at 4257.920000
Oct 28, 2016 02:03:53.325 [7032] DEBUG - Deep Analysis: Read 380000 packets at 4372.704000
Oct 28, 2016 02:03:53.407 [7032] DEBUG - Deep Analysis: Read 390000 packets at 4487.744000
Oct 28, 2016 02:03:53.474 [7032] DEBUG - Deep Analysis: Read 400000 packets at 4602.592000
Oct 28, 2016 02:03:53.552 [7032] DEBUG - Deep Analysis: Read 410000 packets at 4717.963000
Oct 28, 2016 02:03:53.622 [7032] DEBUG - Deep Analysis: Read 420000 packets at 4833.328000
Oct 28, 2016 02:03:53.697 [7032] DEBUG - Deep Analysis: Read 430000 packets at 4948.640000
Oct 28, 2016 02:03:53.769 [7032] DEBUG - Deep Analysis: Read 440000 packets at 5063.648000
Oct 28, 2016 02:03:53.851 [7032] DEBUG - Deep Analysis: Read 450000 packets at 5178.465000
Oct 28, 2016 02:03:53.933 [7032] DEBUG - Deep Analysis: Read 460000 packets at 5293.888000
Oct 28, 2016 02:03:54.009 [7032] DEBUG - Deep Analysis: Read 470000 packets at 5408.695000
Oct 28, 2016 02:03:54.087 [7032] DEBUG - Deep Analysis: Read 480000 packets at 5524.480000
Oct 28, 2016 02:03:54.172 [7032] DEBUG - Deep Analysis: Read 490000 packets at 5639.488000
Oct 28, 2016 02:03:54.251 [7032] DEBUG - Deep Analysis: Read 500000 packets at 5754.432000
Oct 28, 2016 02:03:54.339 [7032] DEBUG - Deep Analysis: Read 510000 packets at 5869.760000
Oct 28, 2016 02:03:54.424 [7032] DEBUG - Deep Analysis: Read 520000 packets at 5985.280000
Oct 28, 2016 02:03:54.502 [7032] DEBUG - Deep Analysis: Read 530000 packets at 6100.135000
Oct 28, 2016 02:03:54.573 [7032] DEBUG - Deep Analysis: Read 540000 packets at 6215.417000
Oct 28, 2016 02:03:54.618 [7032] DEBUG - Deep Analysis: Read 550000 packets at 6331.168000
Oct 28, 2016 02:03:54.672 [7032] DEBUG - Deep Analysis: Read 560000 packets at 6446.784000
Oct 28, 2016 02:03:54.708 [7032] ERROR - [FFMPEG] - Read error at pos. 3017409614 (0xb3da044e)
Oct 28, 2016 02:03:54.710 [7032] DEBUG - Deep Analysis: Sorting packets
Oct 28, 2016 02:03:54.742 [7032] DEBUG - Deep Analysis: Performing file bitrate analysis
Oct 28, 2016 02:03:55.089 [7032] DEBUG - Deep Analysis: Performing stream bitrate analysis on stream 0
Oct 28, 2016 02:03:55.220 [7032] DEBUG - Deep Analysis: Performing stream bitrate analysis on stream 1
Oct 28, 2016 02:03:55.277 [7032] DEBUG - Deep Analysis: Performing stream bitrate analysis on stream 2
Oct 28, 2016 02:03:55.335 [7032] DEBUG - Deep Analysis: Performing stream bitrate analysis on stream 3
Oct 28, 2016 02:03:55.337 [7032] DEBUG
hd movies folder, which is used for dlna, gives me the error when using cloud sync with all the movies, which is what really fails? I should do so not to leave that mistake? thank you very much for your help.
@ChuckPa help,please…
Please confirm or explain more if I do not understand correctly?
All your movies, using cloud sync, fail when you ask Plex to sync them to your Cloud storage?
@ChuckPa yes, all the movies use cloud sync, from my TV Samsung can and plex can access the server in the cloud, the problem comes when I give the play in any film, I get that message"player could not render this content media might be corrupt or the mediatype is not supported", use cloud google drive and my TV model is samsung UE40f6200AW
I would like you to create a new folder.
Copy this movie to the new folder.
Create a new Library and use only that new folder.
Once Plex is ready, Attempt to perform Cloud Sync of that movie. Also attempt to play the movie.
When done, please attach all the log files here for me to look at again
ok, so I will friend, I commented when it does, many thanks.
@ChuckPa hello friend, and done what you told me, here I leave the log, see what you can tell me, greetings.
@ChuckPa you can have a look at the log? Thank you
Got home a couple hours ago (loooooooooooooooooooooong day).
Found some errors:
This is a problem with PMS getting out to the internet. It can’t even see Plex.tv (DNS failure).
Nov 03, 2016 18:39:17.342 [3880] DEBUG - Scanning for plug-ins in C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-d34b464
Nov 03, 2016 18:39:17.350 [3872] ERROR - Error issuing curl_easy_perform(handle): 6
Nov 03, 2016 18:39:17.350 [3872] WARN - HTTP error requesting GET https://plex.tv/servers/f6b4079e18d121f29f9b7581b1bb3242795caf5a/access_tokens.xml?includeProfiles=1&includeProviders=1&auth_token=zhJkmzCApViQR8BxQxsp (0, No error) (Could not resolve host: plex.tv)
Also see this. I have no idea what this means and have asked the devs.
Nov 03, 2016 18:44:02.019 [3860] DEBUG - Completed: [::ffff:127.0.0.1:63596] 206 PUT /video/:/transcode/session/1457c596-a623-459b-ba67-18e4eb1ad6ff/progress?index=2&id=0&codec=ac3&type=audio (9 live) 0ms 190 bytes
Nov 03, 2016 18:44:02.021 [1616] ERROR - [Transcoder] [h264 @ 00a57c20] SEI type 5 size 5560 truncated at 200
Nov 03, 2016 18:44:02.032 [2416] ERROR - [Transcoder] [h264 @ 00a57c20] SEI type 5 size 5560 truncated at 192
Nov 03, 2016 18:44:02.062 [3856] DEBUG - Auth: We found auth token (zhJkmzCApViQR8BxQxsp), enabling token-based authentication.
Found some errors:
@ChuckPa I ask fellow apologize, but this error is very frustrating, then there is no solution possible? I recommend change or touching something? a greeting
