I use Plex music and I had uploaded a .dts audio file, ripped from a dvd. I cut the audio into multiple files (one file per song) and put them in my music folder. Everything worked fine, but I found out that I didn’t cut some songs correctly, so I corrected them. Then I placed the correct songs in the right music folder again and I re-scanned the folder. One song should now be 15 seconds longer, but plex shows the same song duration as before. When I download the file from plex web, I get the correct song, which is 15 seconds longer. I tried a lot to solve this, like changing the name of the files, rescanning the folders again, analyzing the album, refreshing the metadata, but nothing works…
One song also got 1 second longer, but also the duration of this song did not change, it just stops playing 1 second before the end, as the audio file has finished. Can someone help me to let Plex understand that these songs have now a new song duration?
I use a windows server and watch Plex on google chrome at an other windows machine
How did you “cut” those files?
Plex will rely on certain technical header information in your files… if you e.g. use dd to create a 15-sec sample from a much larger file, opening the file will still display its original length.
