Length of Videos are incorrect
Server Version#: 1.30.0.6486
I am not sure if someone has not already reported this issue were some videos are showing the length of a video incorrectly I have tried using the built in features within plex example Fix Match Refresh Metadata Analyze and Un match as well as uninstalling and reinstalling plex completely even deleting the Plex Media Server directory under local and it still shows the length of the videos incorrectly i even moved older videos around that had showed up correctly to see if it would happen to them and once i moved them the length of them are now showing up incorrectly i started to think it had to do with the files itself or whatever so i downloaded emby and they show up correctly so safe to say something is going on with plex itself now I’ve been a plex pass user going on 5 years and this is the first time this has happened
Can you provide some screenshots? PMS will read the duration form the file itself.
