All, looking for some advice as I try to consolidate devices in my media center. Currently have a nVidia Shield TV as my Plex client which can Direct Play pretty much any format to display on my Samsung TV and Denon AVR. I’m looking to replace it with a Sony A9G/F and install Plex as a client on the TV. Does anyone know if the TV can pass through via ARC DTS and Atmos to my Denon and does the Sony Android client have the same capability to Direct Play as the nVidia Shield?
Both the tv, hdmi cable, and receiver must support E-ARC.
All that said, there have been no confirmed tv plex clients that support truehd/atmos over e-arc.
Until proven otherwise, I suspect that E-ARC will only work at the HDMI passthrough level (ie bluray/console), I expect we will not see any tv’s that can pass truehd/atmos over e-arc via plex or other app.
So, if you can get it to work, you might well be the first.
Just to add to what @TeknoJunky asked what model is your Denon?
Many HDMI 2.0 compliant 2017/2018 models had firmware upgrades for e-arc.
Newer ones should already support e-arc.
