Sort by film duration via WebUI bug
Sort by duration, my longest running movies are fine, over 3 hours, 3 hours, 2.75hours etc - great.
Sort the field ascending instead of descending, it’s wild chaos, showing 1:49 films (I know I have shorter) then 1:50 then 2:15, then 1:36, etc? It’s basically broken.
Paying customer here. Between this and the new UI in iOS (WHAT WHERE YOU THINKING) what’s going on with this?
Please address bug.
Stable release, not beta, latest as of todays date, Windows 10x64.
PMS 1.14.1.5488, Win10.
Plex Web 3.81.1 / Chrome / Win10.
Works fine for me. 600+ movies, all listed correctly, whether ascending or descending.
List View
" 3.77.4"
Firefox and Chrome.
Broken here.
Same server version as you.
Try https://app.plex.tv/desktop
That will use the latest version of the web interface.
Plex web does set cookies. Disable tracking blockers if you’ve any installed.
Not sure why it isn’t working for you. It also works OK with 3.77.4 for me. I’m using list view as well.
Thanks for ongoing help- no luck though.
I have 2 Plex servers with the same data on them (long story)
Problem exists for both movies librarys on both servers.
