Is there any way to list TV shows by the resolution? Get a listing of all episodes 1080P or 720P of all episodes on the server. Even just the option per series would be helpful
This only appears to be available for Movie libraries… I’ve seen the sort by resolution filter there, but cannot find it for you in a TV Show library. Sorry,
If you need a list with episodes to ‘upgrade’ their resolution, you can use the Plex2CSV export plugin.
It gives you a list of all episode files in your library, which you can sort and filter in any spreadsheet application.
https://support.plex.tv/hc/en-us/articles/201187656-How-do-I-manually-install-a-channel-
^^ I was thinkin’ that too ^^
