Sort type = different # of movies
I’ve just noticed that if I sort by title Plex tells me I have 1370 movies, but if I sort by any other means (ex: date added) it shows I have 1356 movies. If I count up all the movies in my folders, I get 1354 (I have two versions of one movie that could explain a difference of one, but).
FYI…ExportTools shows 1356
Being the OCD engineer this drives me crazy. Any clue on how to resolve these differences?
Collections
I have 14 collections…so are those the additional names?
Bizarre design choice…but thanks!
if you have enabled collections to show “inline” with your movies, they will also be counted.
you can double-check / change this in the respective library’s advanced settings (Collections):
  • Disabled – collections will be ignored and are only visible when using the collection filter or view
  • Hide items which are in collections – shows only the collections; to access its items you’ll have to open each collection; on your movie library main view this will count the collections but not the items
  • Show items and their collections – shows and counts both: items and collections.
As you pointed out… the inline collections are only included when sorting by title – hence the difference. The number you refer to is not the # of actual movies but the number of visible items.
I dug into Collections a bit and learned a lot about displaying them. I was about to hide the contents until I learned how easy the new Roku Plex app makes collections visible, so now I hide collections in the listings.
Thanks for the tip.
Thanks for clearing that up…
I thought disabled would disable collections, that’s not the case it just disables the view.
IMO I think it should get renamed to “Disable View in this Library”
I worked on this for weeks trying to figure out my miss counts, mine were off in the hundreds…
Thats why I responded with “Collections” and no explanation since I didn’t understand the setting really well, and didn’t want to miss inform. But was hoping for someone to jump in and clear that up.
Thanks tom80H
