Specify domain and port
Is there a way I can specify a domain and port in the form of plex.mydomain.com:32400 when enabling remote access. As opposed to it detecting the public ip address. I am hoping there is some configuration I can edit as I am unable to perform this via the web ui.
I would imagine in the UI it would be as simple as;
Manually specify public port
Manually specify domain name
But in the meantime, I will take editing a config file.
Thanks in advance.
  1. Settings - Server - Networking - Show Advanced
  • You can add your certificate to PMS (It must be aware of it)
    – User cert P12 files must include the CA.
    – Selfsigned certs are not supported.
  • You can specify a customer server access URL which Plex.tv will publish with for your server.
  1. Settiings - Server - Remote Access - Show Advanced
    – You can specify the external port manually (the WAN port of the NAT)
Thanks.
