Server Version#: 1.32.2.7100(-248a2daf0) for Linux
Player Version#: 9.21.2.1271 (c24fffa)
Watching a 4K movie on my Fire Stick 4K Max, and the picture is split in half, but the two halves are pieced the wrong way (left half is on right side, right side is on left). Watched the same file on my Amazon Fire TV and no issues. I got this 4K Max yesterday, and every other 4K movie I’ve watched on it has been fine.
This may be due to HDR10+ with a DV 8.1 profile people were having in this link
opened 05:09PM - 01 Apr 23 UTC
bug
playback
### Describe the bug
When playing a file that has hdr10+ and also dolby vision … profile 8.1 image get full black or duplicate([check here](https://preview.redd.it/vt2p4ee0c2oa1.jpeg?width=4032&format=pjpg&auto=webp&v=enabled&s=606052d50a1bf4922cf1951cc532a63c737beeca)).
This issue occours on all others players too, but kodi appers to have found a solution ([here](https://forum.kodi.tv/showthread.php?tid=371557)). Whe using this version i go do options -> video -> uncheck hdr10+ and video play smoth using Dolby Vision, if keep hdr10+ and dolby vision same issue happens, appers to have some problem with firestick decode that can't play a file with theses two codecs enabled, need to explicit configure player to use one or other
I can play the same file using this kodi modded version without any issue, but using exoplayer/libvlc on jellyfind don't work
### Logs
_No response_
### FFmpeg logs
_No response_
### Media info of the file
```shell
Vídeo
Título: 4K HEVC HDR
Codec: HEVC
Perfil: Main 10
Nível: 150
Resolução: 3832x1596
Proporção da tela: 2.40:1
Entrelaçado: No
Taxa de quadros: 23.976025
Bitrate: 25167 kbps
Profundidade de bits: 10 bit
Intervalo do vídeo: HDR
Video range type: HDR10
DV title: DV Profile 8.1 (HDR10)
DV version major: 1
DV version minor: 0
DV profile: 8
DV level: 6
DV rpu preset flag: 1
DV el preset flag: 0
DV bl preset flag: 1
DV bl signal compatibility id: 1
Espaço de cor: bt2020nc
Transferência de cor: smpte2084
Cores primárias: bt2020
Formato de pixel: yuv420p10le
Quadros de referência: 1
### Application version
latest
### Device information
Amazon Firestick 4k max
### Android version
latest
### Jellyfin server version
latest
I think some people solved it by going into the settings and disabling HDR10+
This is different but may also be somewhat related to an issue in this thread
I’ve noticed an issue on Fire TV 4K Max (Fire OS 7.6.2.4) where it shows a blank/back screen when playing a file (MKV in my testing) with both HDR10+ and DoVi Profile 8.1 metadata. These files playback fine on other Android TV devices like CCwGTV 4K and Sony GTV, but just show a blank/black screen on Fire TV.
For testing, I confirmed that files with just HDR10+ or DoVi P8.1 metadata playback without issue. I also tested separately on both an HDR10+ TV (Samsung) and a Dolby Vision (LG) display t…
Thanks - you’re right in that it’s the same issue with the dovi and hdr10+, thank you! I’ll migrate discussion to that thread
I have this exact same issue with my Fire TV 4K Max. No issues with another Fire TV 4K (TV w/ Fire TV OS built-in). Wondering if this is a Fire TV 4K Max specific issue?
