Hi there. I have Plex Media Server running on my Mac & playing files via the Plex app on Samsung Smart Hub. All was going well then all of a sudden the SRT subtitles stopped working. Now when I go to select subtitles it says there are none but there were before. I have made zero changes to settings or anything else. I also reinstalled the app and server but still no luck. I don’t understand why. If anyone can advise me I’d be very grateful! Thanks.
Server version Please
1.18.2.2029-36236cc4c
When did you upgrade to that version, just before issue?
No I upgraded it after I noticed the issue. So the SRT isn’t working on the previous version or the previous if that makes sense
*isnt working on the new version or previous
I don’t know but there has been a lot of forum noise about the last couple server versions. Maybe a roll back of server is required
Ah ok. So I’m not the only one then? it possible to roll back? Also, I just noticed that subtitles are working on some file but not others. They were all working before.
Very Interesting, you should find on the forum methods of rolling back
Ok. Thanks for your help.
Still no luck. Anyone else have any ideas?
