SSDP WFA Devices adress problem
Server Version#: 1.18.3.2129
Player Version#: 4.12.3 (Web)
NAS Asustor Version#: ADM 3.4.5.RBJ3
Router AC68U Version#: 3.0.0.4.384_45149-g467037b
Hello,
This is my Error on every 30 sec. :
SSDP: Error parsing device schema for http://192.168.1.1:1990/b27887c0-42f2-4498-b2db-2f7d9758d353/WFADevice.xml
followed by Warning every 3 min. :
HTTP error requesting GET http://192.168.1.1:1990/b27887c0-42f2-4498-b2db-2f7d9758d353/WFADevice.xml (0, No error) (Empty reply from server)
and i know why but i cannot change… --> http://192.168.1.1:1990/WFADevice.xml there is no problem (in browser i see) but the …/b27887c0-42f2-4498-b2db-2f7d9758d353/… produce this error
can i change adress of SSPD is searching? or how can i fix this?
someone help? thanks
Your modem/router is advertising itself incorrectly.
If it’s ISP-provided, and you can’t turn off the Advertise flags in the firmware, ignore it.
If it’s your equipment, update the firmware if available or turn it off internally.
thanks for answer me.
now i know where it comes from.
update is last (origin. Asus -> 4G AC68U isn´t Merlin supported) maybe future…
and yeah it´s my equip, could do everthing with it if i could, lool.
but what do you mean to turn off internally?
ASUS AC68U https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AC68U/E14013_RT-AC68U_manual_v2.pdf
The device is likely advertising itself as your wireless gateway on the wired network.
This would be the source of the problem.
If you are using your server over wireless, I strongly suggest you connect it via ethernet cable.
Check the firmware to see if there is an update for it.
If all that is in order, you have no choice but to tolerate the message in the logs and learn to ignore it.
your link --> yeah thats where i was just a few seconds before you wrote…
thanks so much for your information and help !
after restart same error… seems i´ve to accept for a time
my network is wired overall (with AIMesh AC5300 and NAS) without handy and printer and it´s like you wrote a wireless gateway of A1.
no new update … have to wait
I am getting the same issue on PMS & Router is ASUS RT-AC86U running Merlin, Plex is on a wired connection.
So someone pointed me to this thread and especially:
I ran the Python scripts and it finds all ssdp/upnp/dlna servers running in my network and I found the one that was culprit and matched the PMS logs which was @ port 1990 of my Asus Router running Merlin.
So the culprit was WPS and when I disabled it, the errors went away.
If yours is at other IP:Ports in the system, you’ll have to go that particular device and change/turn off particular service, assuming it’s not going to disrupt your current network & devices.
I am also having this issue, EXCEPT that the IP adress (192.168.3.25) does NOT EXIST on my network.
There is NO DEVICE there, so why the error?
  • router attached to modem 3.1
  • printers are in .40’s range
  • servers are in .60’s range
  • ap’s are in the low .100’s range
  • pc’s, tv’s, tablets are dhcp above .140
    I can NOT ping, traceroute this .25 IP nor is it listed in any log on Router, AP’s or switch’s as requesting or having this .25 IP…
    ANY Ideas?
