SSL internal Error
Server Version#:
I have a Server on Ubuntu 20.04 but 3 days ago this message appears on my enigma2 client:
{ E } /usr/lib/python2.7/site-packages/twisted/python/util.py:815 untilConcludes 2021-12-08 23:58:48+0100 [-] ssl.SSLError: [SSL: TLSV1_ALERT_INTERNAL_ERROR] tlsv1 alert internal error (_ssl.c:727)
On my Hisense Tv doesnt work showing “No internet conection” but this works fine on Ytube or Netflix.
Can anybody help me please?
Might this be the problem? It has impacted many users.
Hi, thank you by your answer but i think isn’t the same problem. It starts on 7th dec. Now only the affecteds are my hisense tv and my decoder with Dreamplex over enigma2. If you have any idea that i can try?
Regards
Hisense televisions will 99.9% of the time fall into the above case.
As for the Dreamplex client, you need to refer to the authors / support there.
Logs will be needed for the hisense tv app (player logs) and Plex server logs to determine if it’s something other than the expired certificate problem.
