Should be added a feature like netflix has. After set amount of episodes it should ask if you’re still there.
Soo many entire seasons played while im sleeping
Which client type?
Because some clients have this already implemented, and there are complaints asking for the opposite.
Im using the android tv app. Maybe its there already… Why would anyone want the opposite? Make it a setting then so people can turn it off
I am missing this feature for the xbox one! I really wish you could add it there, since the xbox does not have a sleep timer… at the moment there is nothing I can do to prevent plex playing through the whole night on the xbox.
How about a setting to turn it on or off
