Is it possible to store all metadata in local files within the folder of the media files?
e.g
movies/movie.2001.720p.blabla/poster
/info
/actors
The reason I ask is because it would be neat to be able to “sync” the metadata into the folders when the correct match is made, so I don’t need to worry about having wrong matches if I were to re-add the content later
e.g
/info
/actors
If there is a .nfo file present, Plex will search for the IMDb ID in it and use it additionally as a clue to find the right match. (This applies to movies only, and only if you have a subfolder on disk for each movie)
If you install the .nfo importer agents, you can use Kodi-compatible .nfo files to supply other metadata as well.
plex will read many metadata from the embedded data in a mp4 / m4v file. You need to have the Local Media Assets agent active for this to work.
