I can start providing various samples, but I’ve found Plex Media Server crashes a lot more often since upgrading to 1.7.x, especially on content with 5.1 (or 7.1) DTS-MA. My player is a Roku 4.
Media
General
Unique ID : 224769773440408645038567748235966082232 (0xA919156F14927945BA620CFC9094ECB8)
Complete name : Sing (2016).mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 8.39 GiB
Duration : 1 h 47 min
Overall bit rate mode : Variable
Overall bit rate : 11.1 Mb/s
Encoded date : UTC 2017-03-15 11:43:01
Writing application : mkvmerge v9.2.0 (‘Photograph’) 64bit
Writing library : libebml v1.3.3 + libmatroska v1.4.4
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 5 505 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.111
Stream size : 4.15 GiB (49%)
Writing library : x265 2.3+9-820f4327ddac:[Windows][MSVC 1910][64 bit] 10bit
Encoding settings : cpuid=1173503 / frame-threads=2 / numa-pools=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=155213 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=6 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / bframes=8 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=80 / lookahead-slices=0 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=16 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=1 / dynamic-rd=0.00 / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-1:-1 / no-sao / no-sao-non-deblock / rd=5 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=0.50 / psy-rdoq=5.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=18.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=0.70 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt
Default : Yes
Forced : No
Audio #1
Format : Atmos / TrueHD
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 4 888 kb/s
Maximum bit rate : 8 139 kb/s
Channel(s) : Object Based / 8 channels
Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : / 48.0 kHz
Frame rate : 1 200.000 FPS (40 spf)
Compression mode : Lossless
Stream size : 3.68 GiB (44%)
Title : Dolby Atmos Audio _ 7.1 _ 48 kHz _ 4888 kbps _ 24-bit
Language : English
Default : No
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 494 MiB (6%)
Title : Compatibility Track _ Dolby Digital Audio _ 5.1 _ 48 kHz _ 640 kbps
Language : English
Default : No
Forced : No
Text #1
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 39 min
Bit rate : 15.1 kb/s
Count of elements : 3466
Stream size : 10.7 MiB (0%)
Language : English
Default : No
Forced : No
Text #2
Format : PGS
Muxing mode : zlib
Duration : 1 h 46 min
Bit rate : 9 828 b/s
Count of elements : 2724
Stream size : 7.51 MiB (0%)
Language : French
Default : No
Forced : No
Text #3
Format : PGS
Muxing mode : zlib
Bit rate : 10.4 kb/s
Count of elements : 2934
Stream size : 7.97 MiB (0%)
Language : Spanish
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 1
00:04:29.352 : en:Chapter 2
00:10:36.469 : en:Chapter 3
00:14:04.677 : en:Chapter 4
00:18:32.653 : en:Chapter 5
00:25:14.722 : en:Chapter 6
00:30:04.052 : en:Chapter 7
00:35:11.776 : en:Chapter 8
00:40:07.405 : en:Chapter 9
00:44:36.132 : en:Chapter 10
00:50:26.649 : en:Chapter 11
00:55:36.208 : en:Chapter 12
01:04:40.710 : en:Chapter 13
01:14:03.981 : en:Chapter 14
01:19:17.962 : en:Chapter 15
01:23:59.159 : en:Chapter 16
01:26:56.461 : en:Chapter 17
01:30:38.266 : en:Chapter 18
01:34:47.181 : en:Chapter 19
01:40:16.010 : en:Chapter 20
Logs
Jul 11, 2017 19:56:34.226 [0x7f6e353ff700] ERROR - Error parsing content.
Jul 11, 2017 19:56:34.226 [0x7f6e353ff700] ERROR - Error parsing XML.
Jul 11, 2017 19:56:40.855 [0x7f6e42fff700] WARN - NAT: PMP, timed out waiting for response.
Jul 11, 2017 19:56:47.242 [0x7f6e3effd700] INFO - Refreshing paths watched by LibraryUpdateManager
Jul 11, 2017 19:56:56.245 [0x7f6e32bff700] ERROR - get - invalid frameRate value: 23.976
Jul 11, 2017 19:56:56.566 [0x7f6e40ffd700] INFO - CodecManager: starting EAE at /tmp/pms-95be5b18-c046-4aec-8313-a948694a43b5/EasyAudioEncoder
Jul 11, 2017 19:57:00.157 [0x7f6e3ffff700] WARN - NAT: PMP, timed out waiting for response.
Jul 11, 2017 19:57:00.816 [0x7f6e2ebf7700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (be15e2f3-fdc1-4335-85e2-fe3cb43a7cce, expected 270d720a-c490-463e-9bcc-909dc067de5d)
Jul 11, 2017 19:57:01.636 [0x7f6e323fe700] ERROR - Couldn’t get size of file : boost::filesystem::file_size: No such file or directory
Jul 11, 2017 19:57:51.678 [0x7f6e32bff700] ERROR - Throttle: timed out trying to read chunk 1
Jul 11, 2017 19:58:22.196 [0x7f6e3c3fe700] ERROR - Throttle: timed out trying to read chunk 1
Jul 11, 2017 19:58:23.078 [0x7f6e32bff700] ERROR - Throttle: timed out trying to read chunk 1
Jul 11, 2017 19:59:04.000 [0x7f6e2ebf7700] ERROR - [Transcoder] [truehd_eae @ 0x2f118a0] EAE timeout! EAE not running, or wrong folder? Could not read ‘/tmp/pms-95be5b18-c046-4aec-8313-a948694a43b5/EasyAudioEncoder/Convert to WAV (to 8ch or less)/532ba001b3590191c982b8a5f067ad90_15690-1-4.wav’
Jul 11, 2017 19:59:12.793 [0x7f6e2ebf7700] ERROR - [Transcoder] [truehd_eae @ 0x2f118a0] error reading output
Jul 11, 2017 19:59:12.794 [0x7f6e353ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
Jul 11, 2017 19:59:52.000 [0x7f6e313fc700] ERROR - [Transcoder] [truehd_eae @ 0x3142c40] EAE timeout! EAE not running, or wrong folder? Could not read ‘/tmp/pms-95be5b18-c046-4aec-8313-a948694a43b5/EasyAudioEncoder/Convert to WAV (to 8ch or less)/532ba001b3590191c982b8a5f067ad90_15947-1-131.wav’
Jul 11, 2017 19:59:53.180 [0x7f6e40ffd700] ERROR - [Transcoder] [truehd_eae @ 0x3142c40] error reading output
Jul 11, 2017 19:59:53.180 [0x7f6e353ff700] ERROR - [Transcoder] Error while decoding stream #0:1: Input/output error
