I’m coming in late, but i agree with others, i THOUGHT it was wifi only, but it’s happening on my wired roku as well now.
I haven’t tried to disable HD decoding. I’ll just sit back and watch from this point on, i’m not really contributing, but i’m here to say thanks for looking into this. My issues are exactly on par with what’s been discussed thusfar.
No worries man, you do a lot of work that is greatly appreciated! I have only had this happen on roku and web. Whats up with TMDB? Ive been noticing TVDB changing a lot of stuff recently that temporarily broke my sonarr setup. That was annoying.
Well thanks for all your hard work keeping it all working! Ill make sure to get everything up to date and see how that goes. My wife said this happens on her ios device as well btw.
So it seems it stopped doing this for me. I made 2 changes, and i’m not sure how unrelated they are, but bare with me.
Disabled HW transcoding, it was still stopping early when I disabled this.
Enabled video thumbnails.
Now, #2 i had enabled a while ago, and i have no idea why i disabled it. The reason behind enabling it was this; Since the streams are ending early, i figured it would be easier to find where it ended early again by using the thumbnails. My library is rather large, and it took about 4 days to re-generate them all, but last night i watched maybe 5 things, and none of them stopped early.
It could all be co-incidence, but it seems to have fixed my issue. No idea if it appiles to others or even makes sense? I’m about to turn HW transcoding back on.
This is consistent with my experience. Try turning hw transcoding back on and see if the problem comes back. And if it does, snag some logs as a sacrifice for our Lord and savior, the great and powerful @ChuckPa.
Just a random note, but I started a show on Version 1.18.4.2171 with full hw transcoding to see how it works and its not doing hw decoding. Just thought that was strange.
Happy holidays Chuck! Hope you had a well deserved break! Thanks for all the hard work! I’ll grab some logs sometime tomorrow. In the meantime I saw in console that it said there was no available hardware decoding accelerator available.
I am having this problem as well, and have had the problem for at least a month. I had upgraded PMS to the latest (1.18.3.2156) in the hopes that it would be fixed, but to no avail. I am running PMS on Windows 7 with hardware decoding disabled, using the “Make my CPU hurt” setting. Streaming to two different Roku clients (2019 Streaming Stick+ and 2016 Premiere+) has shown the problem (neither Roku is direct playing due to bandwidth limitations, since I am streaming uncompressed BD rips).
So I currently have HW transcoding turned off, and also the “kill stream when paused after x minutes” option turned off because I swear to god even with HW transcoding turned off I was still seeing some files end early on some devices, and only turning off that kill stream option fixed it.
The kill stream option was the culprit behind the fairly recent issues with Chromecasts. The problems with HW transcoding was causing stuttering and early ending depending on the file regardless of client. Sometimes everything would play fine. Turning off both these features makes everything run smoothly. I can only conclude that these two features, which had both been working pretty good prior to sometime during last summer, are still broken.
I don’t know what made HW transcoding, and kill stream after X minutes features become so bad when they had been so good, but I sure wish we could go back to that.
