Streaming 4K to Nvidia SHIELD
Is it quite normal to have some lag issues with my Plex Media Server (good config) who stream 4k remux content (50-70Mbps & 40-50gb file) over Gigabit Ethernet to a shield (nvidia) client ?
I don’t know what to do to have a smooth playback until the end (sometimes I’ve something good but after a while it’s decreasing !)
I’ve already abandonned the TRUEHD 7.1 audio which complitely screw up … (different messages like not fast enough server or a problem with the network speed…)
I’ve checked so many solutions but none works.
Someone who is in the same situation ? Or it was just not possible today to play full 4K content over ethernet ?!
Thanks so much for the answer.
Some specs :
PMS on Windows 10 - i7 7700k 16gb ram w/ gtx 1080 (plex pass hardware accel ON)
Movie content on a raid 5 Hard Drive tower linked on USB 3 to the PMS
Plex client on Nvidia SHIELD TV, The Android Tv system on my philips oled 55pos9002 is worst by far from the shield… so…
All the house is covered with Gigabit cat 7 SSTP
Properbly the USB3 connection is the problem… Since I reconfigured my setup to SAS Drives and an propper server (HP Microserver gen8 with upgraded CPU) everything works fine.
Thanks for the reply.
I’ve also tested with an internal HDD and that doen’t change …
I don’t have a NAS but with this kind of problems that I have, I think of it ^^
USB3 is or at least should be fast enough.
All my 4K remuxes are on a mix of internal and an 8 bay USB 3 enclosure and play without issue.
I also have them duplicated on Google connected to a remote box and again they play fine in the Shield, Apple TV 4K and LG tv app.
Do you have applied some particular settings to have that work properly fine ? (server & client)
You have your Plex Media Server on a PC or on a NAS ?
On my Philips TV android it’s just to horrible to play (laggggg) so I’ve connected the SHIELD…
No i dont take any special steps.
Server runs on Windows 10.
I don’t use any said at all.
I tend to have all the 4K remuxes on separate drives to minimise anything else causing I/O to the drives.
Just to confirm its not the HDD use CrystalDiskMark and post the results.
(4) WDC WD20EARS-00MVWB0
       Model : WDC WD20EARS-00MVWB0
    Firmware : 51.0AB51
Serial Number : WD-WMAZA1429454
Disk Size : 2000,3 GB (8,4/137,4/2000,3/2000,3)
Buffer Size : Inconnu
Queue Depth : 32
# of Sectors : 3907029168
Rotation Rate : Inconnu
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ----
Transfer Mode : ---- | SATA/300
Power On Hours : 36664 heures
Power On Count : 2590 x
Temperature : 38 C (100 F)
Health Status : Correct
Features : S.M.A.R.T., AAM, 48bit LBA, NCQ
APM Level : ----
AAM Level : 80FEh [OFF]
Drive Letter : F:
– S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 200 200 _51 000000000000 Taux Erreur en Lecture
03 167 165 _21 0000000019F1 Temps moyen mise en rotation
04 _92 _92 __0 00000000206C Décompte des cycles de mise en rotation
05 200 200 140 000000000000 Nombre de secteurs réalloués
07 200 200 __0 000000000000 Taux d’erreurs d’accès des têtes
09 _50 _50 __0 000000008F38 Heures de Fonctionnement
0A 100 100 __0 000000000000 Nombre d’essais de relancement de la rotation
0B 100 100 __0 000000000000 Nombre de recalibration
0C _98 _98 __0 000000000A1E Nombre total de cycles marche/arrêt du disque dur
C0 200 200 __0 0000000000AE Nombre de fois que l’armature magnétique a été rétractée automatiquement suite à une coupure secteur
C1 137 137 __0 00000002EC8B Nombre de fois que la tête a changé de position
C2 112 _98 __0 000000000026 Température interne actuelle.
C4 200 200 __0 000000000000 Nombre d’opérations de réallocation (remap)
C5 200 200 __0 000000000000 Nombre de secteurs “instables”
C6 200 200 __0 000000000000 Nombre total d’erreurs incorrigibles d’un secteur
C7 200 200 __0 000000000000 Nombre d’erreurs dans le transfert de données via le câble d’interface
C8 200 200 __0 000000000000 Nombre total d’erreurs à l’écriture d’un secteur
(6) Lian Li H/W RAID5
   Enclosure : Lian Li H/W RAID5 USB Device (V=152D, P=0551, jm1)
       Model : Lian Li H/W RAID5
    Firmware : 0957
Serial Number : S7P8J4FS2X8387XAFZ5O
Disk Size : 12002,1 GB (8,4/137,4/12002,1/12002,1)
Queue Depth : 1
# of Sectors : 23441702912
Interface : USB (Serial ATA)
Major Version : ATA/ATAPI-7
Power On Hours : Inconnu
Power On Count : Inconnu
Temperature : Inconnu
Health Status : Inconnu
Features : S.M.A.R.T., APM, 48bit LBA
APM Level : 0000h [OFF]
AAM Level : ----
Drive Letter : G:
=> unfortunately doesn’t work on the hard drive tower but the first hard drive is used to sometimes…
I don’t have the c: either… (recent Samsung 960 EVO M2, who run the PMS)
