Streaming Services Not Supported - Jersey
When I try to add services to discover I’m told there are none for my region Jersey.
Jersey is part of the UK (kind of) but we fall under their region for streaming services, so almost all available to the UK are available to Jersey.
The ones that I know 100% work as I’ve used them and are same region as UK are:
  • Netflix
  • Amazon Prime
  • Disney +
Side note, would really appreciate it if Plex just gave us the choice to pick streaming services & what region they fall under. That way I could just select UK for my streaming services.
We already have a ticket with our 3rd. party vendor to make Jersey as UK
Appreciate it, thank you
I can’t get Plex (usual not streaming in Jersey) but my friend does have it (also live in jersey!)
Is there any update on this, as I would also like to start using the Discover function, but can’t as also based in Jersey UK.
Don’t really want to have to keep switching on my vpn
Sadly, we are depending on 3rd. Party vendor here, and no news :frowning:
Why some people in Jersey can access it and others can’t?
Unless some people are using like a VPN, I sadly have no clue
Any update on when this will be available in Jersey?
Sadly not :cry:
Also note, that it’s vacation time, so a great deal of progress might be delayed
Not sure if it’s a glitch or if it’s been fixed but I’m now able to see/select streaming services in Jersey.
