hi all,
my first post after a long day of trying to fix my PMS / Plexconnect / Apple TV 3 experience.
my hardware setup:
-unraid 5.0-rc16c
-pms 0.9.7.28
-plexconnect zip download from 10.08.2013
-atv3 latest firmware (connected with never more than 65mbps to 54 GHz eth2 <- that sucks, can't fix it)
-linksys e4200 v1 with Tomato Firmware 1.28.0000 MIPSR2-112 K26 USB AIO from shibby
-2.4 GHz / eth1 and 5 GHz / eth2, both with WPA2 AES
-wdtv gen1 with wlan N-usb stick (connected to eth1 with 107mbps, same location as the ATV3)
i tried a lot of movie files and tv shows with the plexconnect-ion but on some movie files its starts to stutter and i can't do anything about it. its not fixable at that moment. the latest testmovie that started to stutter, so i had to switch to my WDTV setup was: TPB AFK: The Pirate Bay Away from Keyboard, 6.84 GB, 1080p, H264 1920x1080, Bitrate 11924 kbps
i can't understand why its working on the wdtv with a noname wifi N usb thumb and not on the ATV3 with better wifi hardware like A.
i also tried the both 2,4 and 5 GHz with the atv3. i switched from 20Mhz to 40mhz, from upper to lower (router settings) but nothing helps. i can monitor the bandwith while streaming with the router firmware, and the atv3 is very jumpy from 200KB/s to 3000KB/s.
The WDTV is more stable.
could someone help me? its also irritating me, that the atv3 only connects with 65mbps. anandtech said this is normal (http://www.anandtech.com/show/5687/apple-tv-3-2012-mini-review/3) while someone else got in fact a connection with 150mbps (http://forums.macrumors.com/showpost.php?p=16587559&postcount=12).
any help would be nice, cause i finally want to use one setup and i want to use PMS with all the great features. the wdtv is just a playback thingy.
thanks in advance
pretty disapointing when there is no direct Play for the Video Part
