Stuttering video playback
Server Version#:1.40.0.7998
Player Version#:1.88.1.96-c1c59fc1
I have noticed a few new series stutters during playback. Everything plays fine but these new series. I can not find out why. Same on both plex media player and on HTPC on two different computers with two different gpus and cpus. Same if trans coding or not witch makes it even weirder. Playback quality does not make any difference. Cpu and gpu is no where close to being fully utilized at around 10% during playback. VLC on same file works no problems so no network problem or problem with the files. They are also playing fine without hardware decoding in plex, but with high resource utilization of course. Also everything else seems to play nicely.
Stutters with Hardware Decoding 10% cpu and 10% gpu. Plays fine without but with high cpu/gpu
Codec HEVC
Bitrate 15793 kbps
D O V I B L Compat I D 1
D O V I B L Present true
D O V I Level 6
D O V I Present true
D O V I Profile 8
D O V I R P U Present true
D O V I Version 1.0
Bit Depth 10
Chroma Location topleft
Chroma Subsampling 4:2:0
Coded Height 2160
Coded Width 3840
Color Primaries bt2020
Color Range tv
Color Space bt2020nc
Color Trc smpte2084
Frame Rate 24 fps
Height 2160
Level 5.1
Profile main 10
Ref Frames 1
Width 3840
Display Title 4K DoVi/HDR10 (HEVC Main 10)
Extended Display Title 4K DoVi/HDR10 (HEVC Main 10)
Codec EAC3
Channels 6
Language English
Language Tag en
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Display Title English (EAC3 5.1)
Extended Display Title English (EAC3 5.1)
Codec SRT
Language English
Language Tag en
Title English [SDH]
Display Title English (SRT)
Extended Display Title English [SDH] (SRT)
Plays fine
Codec HEVC
Bitrate 24223 kbps
Language English
Language Tag en
D O V I Level 6
D O V I Profile 8
D O V I Version 1.0
Bit Depth 10
Coded Height 1608
Coded Width 3840
Color Range tv
Color Trc smpte2084
Frame Rate 23.976 fps
Height 1604
Level 5.0
Original true
Profile main 10
Ref Frames 1
Width 3840
Codec EAC3
Channels 6
Bitrate 768 kbps
Language English
Language Tag en
Original true
Codec SRT
Language English
Language Tag en
Original true
Extended Display Title English (SRT)
Also plays fine on plex on android
