FuN_KeY
February 10, 2019, 7:59pm
1
I spent sometime testing the Plex DVR feature and I faced the following problems.
During live TV, I found no way to:
Select audio stream/language
Enable/Disable subtitles. On most channel subtitles are displayed, and I really do not need those.
Even worse, the unwanted subtitles forced transcoding (dvb_subtitles not supported in mpegts…)
Plex server: 1.15.0.659
Client: nvidia shield with latest version
Am I overlooking something or is this some kind of a bug?
Hi @FuN_KeY ,
The one thing I can suggest you check is under Languages in the PMS Server settings, and make sure Subtitle Mode is set to Manual, I had a similar issue and doing this setting cured it for myself on Android, iOS, Roku and Linux Chrome+Plex Media Player.
Just a suggestion, unless you’ve already checked in there…
Dave
FuN_KeY
February 12, 2019, 6:37pm
3
Thank you Dave for the suggestion, this should help.
The thing is, for other media type I like to have auto subtitle. Plex should let me change those settings directly from the live TV interface, as it is for other media type. This limitation does not make sense imho.
Cheers !
I have a related issue, my server can’t transcode fast enough for live or recorded TV with DVB subtitles.
Why do they claim “dvb_subtitles not supported in mpegts”? The release notes from ExoPlayer v2.4.0 say they do support them.
# Release notes #
### 2.9.6 ###
* Remove `player` and `isTopLevelSource` parameters from `MediaSource.prepare`.
* IMA extension:
* Require setting the `Player` on `AdsLoader` instances before
playback.
* Remove deprecated `ImaAdsMediaSource`. Create `AdsMediaSource` with an
`ImaAdsLoader` instead.
* Remove deprecated `AdsMediaSource` constructors. Listen for media source
events using `AdsMediaSource.addEventListener`, and ad interaction events by
adding a listener when building `ImaAdsLoader`.
* Allow apps to register playback-related obstructing views that are on top of
their ad display containers via `AdsLoader.AdViewProvider`. `PlayerView`
implements this interface and will register its control view. This makes it
possible for ad loading SDKs to calculate ad viewability accurately.
* DASH: Fix issue handling large `EventStream` presentation timestamps
([#5490](https://github.com/google/ExoPlayer/issues/5490)).
* HLS: Fix transition to STATE_ENDED when playing fragmented mp4 in chunkless
This file has been truncated. show original
" * Support DVB subtitles in MPEG-TS and MKV."
So, DVB subtitles shouldn’t trigger transcode, can we have this fixed for Android?
system
Closed
June 14, 2019, 9:04pm
5
