Is there a way to make the subtitles less bright on Android tv?
When watching HDR, the subtitles are so bright when you’re in the dark.
i know you can change the colour but we need semi transparent or something darker.
My client (on the Shield) has additional colors at the end of the list (in Preferences). Light grey, blended light grey and the same in yellow.
Try one of those.
(This preference only works with subtitles in ‘text’ format, like SRT. It won’t work with PGS or Vobsub subtitles.)
