First of all, i reckon i am stupid since i have read the forums for nearly 3 weeks and still dont understand
Simple question: I am on a Mac enviroment. Movies will be streamed throught airport express. All my movies are in m4v format with subtitles.
Will the QNAP TS-453 Be work for me? I still dont understand if i need transcoding or not. Once again, my media is M4V, 1080p and will be only streamed through apple tv 4
The TS-453 Be will do a great job handling the video itself because it has hardware assist (if you have a PlexPass to enable it).
Subtitles always require the CPU (there is no HW support for subtitles out there yet).
This is where youâll run into problems.
If the subtitles are text based (SRT, ASS, or SSA names), the apps will overlay them on your screen ok.
If they are image based (names: PGS, VOBSUB, DVDRIP) then the CPU has to merge those images with the video image. Thatâs where it gets messy. The CPU is easily overloaded and playback can get sluggish.
If you take time and curate the media to have only those subtitle formats you need and want, youâll have a good experience.
There is a lot of info to absorb. It does take time.
Donât let it get you down. Go slow, read, try, learn. youâll get there.
First of all, thank you for taking the time to answer. Honestly i am from south america and Nas are quite expensive in here. Didnt want to spend money on something that wont work.
Now, just to clarify. All my subtitles are inside M4v containers, all are srt format. I wont need to transcode to my iphone.
If i understood correctly, this should work fine? Without movies freezing on my apple tv?
Once again, thank you Chuck. You are the reason i am buying the plex pass.
And what if i were to use the Nas only as external storage and run the server on the imac? Would i have any kind of trouble with my current files? I dont feel like reconverting a 3k movies library to hardcode subtitles
So i buy any nas and i run the server on the imac, would that work just fine?
If you use a different computer to run the server, the computational needs of the NAS drop significantly. It only needs the power to read / write the network at whatever peak speed you have demands for.
An ARMv8 system will do an excellent job at that with multiple concurrent gigabit connections. It isnât the strongest Media Server but itâs one heck of a file server.
There is currently one in use that is connected to the airport express. For some reasons I donât remember, when they installed it they put it on bypass or something like that, so what gives internet to all the rest of the devices is the airport express.
On different rooms I have 2 atv4 and one laptop (MacBook Air)
On the same room of the wifi, lies the iMac (which will work as Plex server) but far from the router and the airport express. Like 4 meters away.
So basically now I need to buy the Nas (btw thinking of purchasing the QNAP Ts431 which is really cheap and comes with 4 bays), and a switch to connect the iMac, The airport, and the Nas to it? Is that correct? All those connections via ethernet cables?
Can I use the 3 unused ethernet ports of the sage com instead?
My friend
i hope this conversation is useful for others.
As far as i am concerned (and i didnt know nothing about connections, Nas and transcoding), i now feel i ll be capable of buying the proper devices and to understand why i need it. You did a wonderful job!
