Hi all,
I’ve not really used subtitles much in the past but since ripping my library I am finding I am needing them in certain areas.
I have installed Sub Zero and generally got it to work, kinda.
For some movies it wont download any subtitles, it runs the meta data update but not subtitles will be present after. Is that normal?
Where it does find subtitles most of them are completely out of sync with what’s happening on screen. Is there a correct fix for this kind of issue that anyone would know about please?
Many thanks.
