Subtitles problem
Hello guys,
I have a problem with my ATV3 with ReadyNAS Ultra. It won't load any subtitles, weather it's external .srt files or incorporated subs (UNK).
Furthermore, some of the BluRay rips will keep buffering if I try to show subtitles, and run perfect without.
Help?!
It’s probably because your NAS isn’t powerful enough to transcode (it is attempting to burn the subs into the image on the fly).
Convert your subs to an aTV natively supported format.
See this post for useful info (ignore the Hebrew bit):
http://forums.plexapp.com/index.php/topic/73364-request-option-to-use-the-substitles-with-the-native-player-too/?p=423731
It's probably because your NAS isn't powerful enough to transcode (it is attempting to burn the subs into the image on the fly).
Just a small correction as I keep seeing this a lot. SRT subtitles are not being burn-in since PMS 0.9.7.27  Instead, they are being streamed via HLS (this still requires some horse power on your PMS). This is, at least, the case if you have compatible H.264 video stream inside your file.
