Dear Developers,
I am using rasplex for my video's and it's a wonderfull program!
Although, entering the rasplex with ssh and trying to use the command "sudo", I was not able to do it.
The system just said "this command cannot be used".
Can somebody tell me if there is a good reason for this and how I could make this work?
I am interested in installing an extra client next to rasplex for music but therefore I need to use some linux commands.
Thanks in advance!
Its already logged in as root so no need for sudo.
RasPlex:~ #
Thanks for the reply Morey!
One extra question: since I am using openelec, I cannot use the package manager.
Because want to install some extra libraries (libflac-dev, libfaad2 and libmad0) I am looking for a solution.
I already downloaded these packages manually (not with all the dependencies but still...).
My question: since I don't have any .DEB package installer installed, how can I install the single/manual downloaded .DEB files?
Thanks already in advance!
