sudo: ./PlexConnect.py: command not found
Hi.  I installed PlexConnect successfully a couple weeks ago and it's been great.  My MacMini crashed the other day for an unrelated reason, though, and now I'm getting the following message when I type sudo ./PlexConnect.py from Python:
My PlexConnect folder (which is in my applications folder) is labeled "PlexConnect-master."
I'd really appreciate any ideas anyone may have.  Thanks.
Here are my specs:
ATV3 software 6.0 (6646.65) OS 7.02 (11A502)
DNS 10.0.1.50
MacMini OS 10.9
PlexConnect local IP 10.0.1.50
PMS installed on same MacMini OS 10.9
PMS local IP 10.0.1.50
PMS version 0.9.8.7
PlexConnect: Created November 10, 2013 at 5:10 AM
Settings.cfg and PlexConnect.log attached.
Did you change to the right directory in terminal before executing the command?
Here are my specs:
DNS 10.0.1.50
MacMini OS 10.9
PMS version 0.9.8.7
1) where did you get the PlexConnect log from, if the complete application is not found - thus can't be running?
2) settings - your certfile path is wrong, if your PlexConnect lived in PlexConnect-master -> look at your log. :-)
No.  I'm a novice...how would I do this?
1.) I got the PlexConnect log by double clicking the PlexConnect.log file in my PlexConnect-master folder.
2.) OK, I changed the PlexConnect folder name from "PlexConnect-master" to "PlexConnect" in order to match the path to the trailers.pem cert path in the Settings.CFG file, but I still get the same "command not found" at the terminal and "Failed to access certificate" in the log.
in your terminal window, type "cd" followed by the path you want to go to - eg. cd /Applications/PlexConnect
Please check the timestamp of your log...
If your error still persists (command not found), PlexConnect can't run... therefore you don't get a valid log. The one in your directory must be outdated, I guess. At least both files (log from first post, NewLog from this) are the same.
Thank you!
