At SudoBox our ambition is to give you an effortless, fully automated media box installation. SudoBox comes complete with a clean, intuitive easy to use UI eliminating the need for backend command-line interaction. Our main priorities at SudoBox are security, ease of use, and convenience. Our tools are entirely dockerized and customizable enabling you to administer more efficiently from within our dashboard. We have a strong sense of pride in project SudoBox, not hours but months have been poured into this. We’ve loved putting together SudoBox and we wish to carry it on for as long as we can. We are aiming to strive towards being fully supported on multiple operating systems. . . Starting with Linux. We’ve loved putting together SudoBox and we wish for it only to grow.
Come check us out at https://sudobox.io/
Single Command, Multi-OS Install Script
Sudobox is committed to making a dynamic automated project, as such, provides a single command to install our entire application on a multitude of Operating Systems.
GUI Installation Wizard
Sudobox comes with a simple, elegant, easy to use installation wizard which allows for easy deployment
Versatile Docker-based System
Sudobox is completely dockerized, and uses a unique docker management system to allow the addition of custom docker containers, including a library of templates for one-click deployments, which is all accessible from Sudobox’s Web Interface
Built in Docker Management System
Striving to make a convenient all-in-one user interface, we have coded from scratch a docker management system to monitor, edit and maintain all your installed docker containers.
