Suggestion: Open folder
Hi, I would like to suggest an option in the Windows Plexamp application. I use this feature a lot on AIMP currently but want to completely centralise my library in Plex.
When playing a track, I would like the option to Right-Click and Open Folder (containing current playing track). I play a large library of music on random and this feature would help me to track down songs I like to be able to add them to a USB memory stick for playback in the car.
I haven’t listened to a lot of music in my library and would find this feature very helpful when I find a new hidden gem.
Many thanks
Keep in mind this will only work if your Windows has access to the underlying Plex Media Server. That might be the case if the server and Plexamp are running on the same machine… less so if your server is hosted on some other device in (or outside) your network and only the PMS having access to the actual media.
You know you can play stream directly from Plexamp to a connected Android Auto, Car Play or e.g. bluetooth connected audio system from Plexamp on your phone? You can also download media to the phone using Plexamp and play that the same way.
Not sure you really want to go the route of manually loading it on a stick to take that with you instead.
