Summary field (automatic) collections back to default after reboot
Server Version#: 1.41.3.9314
Player Version#: 1.106.0.276-fe8d1d20 (Windows)
I generated Automatic Collections for my movies. Everything is generated fine and now i need to change some summary’s that are not completed. I can change it, lock it but if i reboot Plex the summary is going back to “default” summary. This also happening without a reboot, but it then takes some time. Other summary’s (movies or manual created collections still working fine).
Trying to do already:
Turn off automatic collections
Unlock the fields, reboot, edit and lock again, reboot
Optimise database
I uploaded the log when starting the server\the problem happend.
I see a lot of database fixeups for collections for example:
Jan 13, 2025 07:46:35.431 [2536] WARN - [DatabaseFixups] Held transaction for too long (D:\gha\plex-media-server\plex-media-server\Library\MetadataCollection.cpp:525): 9.593750 seconds
Jan 13, 2025 07:46:35.435 [2536] DEBUG - [DatabaseFixups] Collections: Refreshed attributes for 0 collections in section 10 in 3704ms.
Jan 13, 2025 07:46:36.577 [2536] DEBUG - [DatabaseFixups] Collection: Refreshed visibility in section 10 in 1142ms.
Jan 13, 2025 07:46:37.993 [2536] DEBUG - [DatabaseFixups] Collections: Found 7 collections tags in section 11.
Jan 13, 2025 07:46:37.994 [2536] DEBUG - [DatabaseFixups] Collections: We had 7 collections in the library already.
Jan 13, 2025 07:46:37.994 [2536] DEBUG - [DatabaseFixups] Collections: Synced tags in section 11 in 1415ms.
Jan 13, 2025 07:46:39.121 [2536] WARN - [DatabaseFixups] Held transaction for too long (D:\gha\plex-media-server\plex-media-server\Library\MetadataCollection.cpp:525): 2.953125 seconds
Jan 13, 2025 07:46:39.124 [2536] DEBUG - [DatabaseFixups] Collections: Refreshed attributes for 0 collections in section 11 in 1130ms.
Jan 13, 2025 07:46:40.207 [2536] DEBUG - [DatabaseFixups] Collection: Refreshed visibility in section 11 in 1082ms.
Jan 13, 2025 07:46:41.436 [2536] DEBUG - [DatabaseFixups] Collections: Found 0 collections tags in section 12.
Jan 13, 2025 07:46:41.437 [2536] DEBUG - [DatabaseFixups] Collections: We had 0 collections in the library already.
Jan 13, 2025 07:46:41.437 [2536] DEBUG - [DatabaseFixups] Collections: Synced tags in section 12 in 1229ms.
Jan 13, 2025 07:46:42.532 [2536] DEBUG - [DatabaseFixups] Collections: Found 0 collections tags in section 12.
Jan 13, 2025 07:46:42.533 [2536] DEBUG - [DatabaseFixups] Collections: We had 0 collections in the library already.
Jan 13, 2025 07:46:42.533 [2536] DEBUG - [DatabaseFixups] Collections: Synced tags in section 12 in 2325ms.
Jan 13, 2025 07:46:43.692 [2536] DEBUG - [DatabaseFixups] Collections: Found 1 collections tags in section 12.
Jan 13, 2025 07:46:43.692 [2536] DEBUG - [DatabaseFixups] Collections: We had 1 collections in the library already.
Jan 13, 2025 07:46:43.692 [2536] DEBUG - [DatabaseFixups] Collections: Synced tags in section 12 in 3484ms.
I see 1 person in the past with the same problem, but no so
Plex Media Server.log (164.0 KB)
lution: Editing/Saving Summary verbiage in Movie Collections.
Hopefully somebody can help.
Greetings, Marcel
Update 24-1, uploaded some extra logging. Still not getting it working, seems like a bug in the software, because every other field is properly saved in the database.
Plex Media Server Logs_2025-01-24_20-46-10.zip (3.1 MB)
