I have an ODROID-XU3 ARM device that I am running ArchLinux on and the Plex Media Server.
As you may know the XU3 is an 8-core samsung device and I have found that it is totally sufficient to transcode even the worse 1080p divx or other content to the web client.
(Other clients like Android or the PHT that do transcoding on the client hardware have been eliminated from my testing)
So I and others are annoyed at the "This server is not powerful enough .." message that prevents transcoding the above content.
(In testing I have disabled that test by inserting a "return false" in the validateTranscoder() function in the plex.js script)
I have tested as much content as possible to know that this hardware is capable of the most demanding transcode demands. The 8-cores are hardly used for most content and at it's worse
the CPU's are at 70% on 4-cores, the other ones <10% .. (Another user I have been in contact with has the same results as me ..)
So can I please request that you re-look at how this function determines the hardware is good enough.
At the moment every update over-writes the changes I do to this file, so I have to edit it frequently to use my system again to it's full potential..
Who compiled the version you are using? I have a xu3 I want to test but I want a build with the big.LITTLE endian switch added so it will use all 8 cores not just the arm7. Where exactly are the dev based forums as the layout here is kinda confusing.
I’ll be only too happy to provide info for the -XU3 if you want … just let me know what you want.
cpuinfo shows:
[builder@server ~]$ cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 3 (v7l)
BogoMIPS : 78.00
Features : swp half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 3
processor : 1
BogoMIPS : 78.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 3
processor : 2
BogoMIPS : 78.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 3
processor : 3
BogoMIPS : 78.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xc07
CPU revision : 3
processor : 4
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x2
CPU part : 0xc0f
CPU revision : 3
processor : 5
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x2
CPU part : 0xc0f
CPU revision : 3
processor : 6
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x2
CPU part : 0xc0f
CPU revision : 3
processor : 7
BogoMIPS : 108.00
CPU architecture: 7
CPU variant : 0x2
CPU part : 0xc0f
CPU revision : 3
Hardware : ODROID-XU3
Revision : 0000
Serial : 0000000000000000
Ya basically. I can’t do anything to help but I would suggest tagging the primary post with as many relevant tags as you can. The organization here for feature requests is pretty abysmal and while this may be simple for them, there isn’t any guarantee a staff member will see it. Tags may help with that.
You are dead right there. It seems from another thread that the only way dev’s will notice a topic is by voting with the dreadful facebook “like” system …
It seems, we are just a number … so there does not seem to be any alternative, but to play this silly game and vote up this topic …
Is there a way to contact Plex developers some other way? By email for example.
Just interesting why “Linux” download section still does not have “ARM” option.
Developers usually do not respond to feature requests. They just use the like count to help guide their development. If there are enough votes to garner putting in the effort, they may add it to their todo list, but they do not reveal what is on that list. This post currently has 6 likes, so although it may be important to you, it is not winning over other users.
I am confused though. If you were able to compile your own version, why not just use that. I know there is at least 1 other linux build that is currently managed by a user. If you shared your work and it became popular, that would be another way to get Plex’s attention for an official version.
The problem is that I can not compile version for required platform with needed flags because plex is not open source. I’m not sure about that linux build. I think that mentioned user just uses binary extracted from some other linux package and packs it to needed format. Only Plex developers have access to source code.
Talking about Odroid – we also may use binary for some ARM NAS, but build for Odroid may be optimized if compiled with big.LITTLE endian switch. And the main problem of all ARM builds that we can not control transcoding. It’s just disabled. We can enable it for web interface by changing portal javascript code. And Odroid’s 2Ghz CPU is enough to transcode HD 720p. But this does not work, for example, for iOS app.
All ARM builds have the same problem – transcoding is disabled. So It might be a good idea to let users decide if they want to use transcoding. I don’t understand why we don’t have such preference.
