It starts like this but it can’t keep up:(firefox as player this time playing content just recorded)
Summary
Jul 27, 2019 11:34:11.246 [0x7fc1c455b700] DEBUG - MDE: Tour de France - S2019 E20 - Stage 20: Albertville to Val Thorens: selected media 0 / 8737
Jul 27, 2019 11:34:11.246 [0x7fc1c455b700] DEBUG - Streaming Resource: Calculated bandwidth of 20393kbps exceeds bandwidth limit. Changing decision parameters provided by client to fit bandwidth limit of 3000kbps
Jul 27, 2019 11:34:11.246 [0x7fc1c455b700] DEBUG - Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Jul 27, 2019 11:34:11.246 [0x7fc1c455b700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Jul 27, 2019 11:34:11.254 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x32315659 -> yuv420p.
Jul 27, 2019 11:34:11.254 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x30323449 -> yuv420p.
Jul 27, 2019 11:34:11.254 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x3231564e -> nv12.
Jul 27, 2019 11:34:11.254 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x32595559 -> yuyv422.
Jul 27, 2019 11:34:11.254 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x59565955 -> uyvy422.
Jul 27, 2019 11:34:11.254 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x48323234 -> yuv422p.
Jul 27, 2019 11:34:11.254 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x58424752 -> rgb0.
Jul 27, 2019 11:34:11.254 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x58524742 -> bgr0.
Jul 27, 2019 11:34:11.254 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x30313050 -> p010le.
Jul 27, 2019 11:34:11.254 [0x7fc1c455b700] DEBUG - [FFMPEG] - Created surface 0x4000000.
Jul 27, 2019 11:34:11.254 [0x7fc1c455b700] DEBUG - [FFMPEG] - Direct mapping possible.
Jul 27, 2019 11:34:11.255 [0x7fc1c455b700] DEBUG - Scaled up video bitrate to 19165Kbps based on 1.500000x fudge factor.
Jul 27, 2019 11:34:11.255 [0x7fc1c455b700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Jul 27, 2019 11:34:11.259 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x32315659 -> yuv420p.
Jul 27, 2019 11:34:11.259 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x30323449 -> yuv420p.
Jul 27, 2019 11:34:11.259 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x3231564e -> nv12.
Jul 27, 2019 11:34:11.259 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x32595559 -> yuyv422.
Jul 27, 2019 11:34:11.259 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x59565955 -> uyvy422.
Jul 27, 2019 11:34:11.259 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x48323234 -> yuv422p.
Jul 27, 2019 11:34:11.259 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x58424752 -> rgb0.
Jul 27, 2019 11:34:11.259 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x58524742 -> bgr0.
Jul 27, 2019 11:34:11.260 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x30313050 -> p010le.
Jul 27, 2019 11:34:11.260 [0x7fc1c455b700] DEBUG - [FFMPEG] - Created surface 0x4000000.
Jul 27, 2019 11:34:11.260 [0x7fc1c455b700] DEBUG - [FFMPEG] - Direct mapping possible.
Jul 27, 2019 11:34:11.260 [0x7fc1c455b700] DEBUG - Scaled up video bitrate to 19165Kbps based on 1.500000x fudge factor.
Jul 27, 2019 11:34:11.261 [0x7fc1c455b700] DEBUG - Streaming Resource: Reducing playback quality for 2857kbps stream bitrate: video resolution to 720x406, audio channels to 2, quality to 84
Jul 27, 2019 11:34:11.261 [0x7fc1c455b700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Jul 27, 2019 11:34:11.264 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x32315659 -> yuv420p.
Jul 27, 2019 11:34:11.264 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x30323449 -> yuv420p.
Jul 27, 2019 11:34:11.264 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x3231564e -> nv12.
Jul 27, 2019 11:34:11.264 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x32595559 -> yuyv422.
Jul 27, 2019 11:34:11.264 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x59565955 -> uyvy422.
Jul 27, 2019 11:34:11.264 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x48323234 -> yuv422p.
Jul 27, 2019 11:34:11.264 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x58424752 -> rgb0.
Jul 27, 2019 11:34:11.264 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x58524742 -> bgr0.
Jul 27, 2019 11:34:11.264 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x30313050 -> p010le.
Jul 27, 2019 11:34:11.264 [0x7fc1c455b700] DEBUG - [FFMPEG] - Created surface 0x4000000.
Jul 27, 2019 11:34:11.264 [0x7fc1c455b700] DEBUG - [FFMPEG] - Direct mapping possible.
Jul 27, 2019 11:34:11.265 [0x7fc1c455b700] DEBUG - Scaled up video bitrate to 19165Kbps based on 1.500000x fudge factor.
Jul 27, 2019 11:34:11.265 [0x7fc1c455b700] DEBUG - Scaled maximum bitrate for resolution reduction to 2701Kbps.
Jul 27, 2019 11:34:11.265 [0x7fc1c455b700] DEBUG - MDE: Selected protocol dash; container: mp4
Jul 27, 2019 11:34:11.265 [0x7fc1c455b700] DEBUG - MDE: analyzing media item 8737
Jul 27, 2019 11:34:11.265 [0x7fc1c455b700] DEBUG - MDE: E20 - Stage 20: Albertville to Val Thorens: Direct Play is disabled
Jul 27, 2019 11:34:11.265 [0x7fc1c455b700] DEBUG - MDE: E20 - Stage 20: Albertville to Val Thorens: media must be transcoded in order to use the dash protocol
Jul 27, 2019 11:34:11.265 [0x7fc1c455b700] DEBUG - MDE: E20 - Stage 20: Albertville to Val Thorens: no direct play video profile exists for http/mpegts/mpeg2video
Jul 27, 2019 11:34:11.265 [0x7fc1c455b700] DEBUG - MDE: E20 - Stage 20: Albertville to Val Thorens: no direct play video profile exists for http/mpegts/mpeg2video/ac3
Jul 27, 2019 11:34:11.266 [0x7fc1c455b700] DEBUG - Stage 20: Albertville to Val Thorens - video.width limitation applies: 1920 > 720
Jul 27, 2019 11:34:11.266 [0x7fc1c455b700] DEBUG - Stage 20: Albertville to Val Thorens - audio.channels limitation applies: 6 > 2
Jul 27, 2019 11:34:11.266 [0x7fc1c455b700] DEBUG - MDE: E20 - Stage 20: Albertville to Val Thorens: Direct Streaming is disabled, so video stream will be transcoded
Jul 27, 2019 11:34:11.266 [0x7fc1c455b700] DEBUG - MDE: E20 - Stage 20: Albertville to Val Thorens: no remuxable profile found, so video stream will be transcoded
Jul 27, 2019 11:34:11.266 [0x7fc1c455b700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Jul 27, 2019 11:34:11.266 [0x7fc1c455b700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Jul 27, 2019 11:34:11.267 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x32315659 -> yuv420p.
Jul 27, 2019 11:34:11.267 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x30323449 -> yuv420p.
Jul 27, 2019 11:34:11.267 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x3231564e -> nv12.
Jul 27, 2019 11:34:11.267 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x32595559 -> yuyv422.
Jul 27, 2019 11:34:11.267 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x59565955 -> uyvy422.
Jul 27, 2019 11:34:11.267 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x48323234 -> yuv422p.
Jul 27, 2019 11:34:11.267 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x58424752 -> rgb0.
Jul 27, 2019 11:34:11.267 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x58524742 -> bgr0.
Jul 27, 2019 11:34:11.267 [0x7fc1c455b700] DEBUG - [FFMPEG] - Format 0x30313050 -> p010le.
Jul 27, 2019 11:34:11.267 [0x7fc1c455b700] DEBUG - [FFMPEG] - Created surface 0x4000000.
Jul 27, 2019 11:34:11.267 [0x7fc1c455b700] DEBUG - [FFMPEG] - Direct mapping possible.
Jul 27, 2019 11:34:11.268 [0x7fc1c455b700] DEBUG - Scaled up video bitrate to 19165Kbps based on 1.500000x fudge factor.
Jul 27, 2019 11:34:11.268 [0x7fc1c455b700] DEBUG - Scaled maximum bitrate for resolution reduction to 2701Kbps.
Jul 27, 2019 11:34:11.268 [0x7fc1c455b700] DEBUG - MDE: E20 - Stage 20: Albertville to Val Thorens: Audio Direct Streaming is disabled, so video’s audio stream will be transcoded
Jul 27, 2019 11:34:11.269 [0x7fc1c455b700] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
Jul 27, 2019 11:34:11.269 [0x7fc1c455b700] DEBUG - MDE: Tour de France - S2019 E20 - Stage 20: Albertville to Val Thorens: selected media 0 / 8737
Jul 27, 2019 11:34:11.270 [0x7fc1c455b700] DEBUG - Streaming Resource: Reached Decision id=7833 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=8737 part=(id=8737 decision=transcode container=mp4 protocol=dash streams=(Video=(id=5983 decision=transcode bitrate=2613 encoder=h264_vaapi width=720 height=406) Audio=(id=5985 decision=transcode bitrate=232 encoder=aac channels=2 rate=48000))))
Jul 27, 2019 11:34:11.270 [0x7fc1c455b700] DEBUG - Transcode Session: Going to restart at offset 84.017349 with segment number 27
Jul 27, 2019 11:34:11.270 [0x7fc1c455b700] DEBUG - Killing job.
Jul 27, 2019 11:34:11.270 [0x7fc1c455b700] DEBUG - Signalling job ID 8581 with 9
Jul 27, 2019 11:34:11.271 [0x7fc1c455b700] DEBUG - Job was already killed, not killing again.
Jul 27, 2019 11:34:11.271 [0x7fc1c455b700] DEBUG - Stopping transcode session 94qmjsmawjsremf7w6dvvkwb
Jul 27, 2019 11:34:11.271 [0x7fc1c455b700] DEBUG - Starting a transcode session 94qmjsmawjsremf7w6dvvkwb at offset 84.0 (state=3)
Jul 27, 2019 11:34:11.272 [0x7fc1c455b700] DEBUG - TPU: hardware transcoding: using hardware decode accelerator vaapi
Jul 27, 2019 11:34:11.273 [0x7fc1c455b700] DEBUG - [Universal] Using local file path instead of URL: /volume1/Plex/shows/Tour de France (2019)/Season 2019/Tour de France (2019) - 2019-07-27 07 00 00 - Stage 20.ts
Jul 27, 2019 11:34:11.273 [0x7fc1c455b700] DEBUG - TPU: hardware transcoding: zero-copy support present
Jul 27, 2019 11:34:11.273 [0x7fc1c455b700] DEBUG - TPU: hardware transcoding: not using zero-copy because video is interlaced
Jul 27, 2019 11:34:11.274 [0x7fc1c455b700] DEBUG - TPU: hardware transcoding: final decoder: vaapi, final encoder: vaapi
Jul 27, 2019 11:34:11.275 [0x7fc1c455b700] DEBUG - Job running: EAE_ROOT=’/volume1/Plex/tmp_transcoding/pms-e4395390-2184-45b1-a5f7-9aa97f538756/EasyAudioEncoder’ FFMPEG_EXTERNAL_LIBS=’/volume1/Plex/Library/Application\ Support/Plex\ Media\ Server/Codecs/2144ff1-2376-linux-x86_64/’ XDG_CACHE_HOME=’/volume1/Plex/Library/Application Support/Plex Media Server/Cache’ XDG_DATA_HOME=’/volume1/@appstore/Plex Media Server/Resources’ X_PLEX_TOKEN=‘xxxxxxxxxxxxxxxxxxxx’ ‘/volume1/@appstore/Plex Media Server/Plex Transcoder’ ‘-codec:#0x100’ ‘mpeg2video’ ‘-hwaccel:#0x100’ ‘vaapi’ ‘-hwaccel_fallback_threshold:#0x100’ ‘10’ ‘-codec:#0x101’ ‘ac3’ ‘-ss’ ‘83.967998999999992’ ‘-analyzeduration’ ‘20000000’ ‘-probesize’ ‘20000000’ ‘-i’ ‘/volume1/Plex/shows/Tour de France (2019)/Season 2019/Tour de France (2019) - 2019-07-27 07 00 00 - Stage 20.ts’ ‘-filter_complex’ ‘[0:#0x100]yadif[0];[0]scale=w=720:h=406[1];[1]format=pix_fmts=nv12[2];[2]select=gte(t,83.983983)[3];[3]hwupload[4]’ ‘-filter_complex’ ‘[0:#0x101] aresample=async=1:ocl=’’‘stereo’’’:osr=48000[5]’ ‘-map’ ‘[4]’ ‘-codec:0’ ‘h264_vaapi’ ‘-b:0’ ‘1959k’ ‘-maxrate:0’ ‘2613k’ ‘-bufsize:0’ ‘5226k’ ‘-r:0’ ‘29.969999999999999’ ‘-force_key_frames:0’ ‘expr:gte(t,84+n_forced*3)’ ‘-map’ ‘[5]’ ‘-metadata:s:1’ ‘language=eng’ ‘-codec:1’ ‘aac’ ‘-b:1’ ‘232k’ ‘-bsf:1’ ‘framedrop=count=2’ ‘-f’ ‘dash’ ‘-min_seg_duration’ ‘3000000’ ‘-skip_to_segment’ ‘28’ ‘-time_delta’ ‘0.0625’ ‘-manifest_name’ ‘http://127.0.0.1:32400/video/:/transcode/session/94qmjsmawjsremf7w6dvvkwb/5710eeab-f048-4468-bc32-16a4e4599ed8/manifest’ ‘-avoid_negative_ts’ ‘disabled’ ‘-map_metadata’ ‘-1’ ‘-map_chapters’ ‘-1’ ‘dash’ ‘-start_at_zero’ ‘-copyts’ ‘-y’ ‘-vaapi_device’ ‘/dev/dri/renderD128’ ‘-nostats’ ‘-loglevel’ ‘quiet’ ‘-loglevel_plex’ ‘error’ ‘-progressurl’ ‘http://127.0.0.1:32400/video/:/transcode/session/94qmjsmawjsremf7w6dvvkwb/5710eeab-f048-4468-bc32-16a4e4599ed8/progress’
