Thanks, yea it’s a nice NAS but yea $300 is a lot for an extra bay some memory might as well go with the DS918+.
Does the DS1819+ support hardware transcoding though?
I don’t think it has a Apollolake CPU
Hm ok, I found a used Synology DS1812+ I probably can get for around €750, or just get a new DS918+
At the moment I have a QNAP TS 421 with 4 drives already but it’s only around 11 TB in total, it has 3x3TB WD Red drives and 1x2TB WD RED
I want to replace it a new one with at least 2x10TB drives.
I also want to be able to run Docker, with these containers: sonarr, radarr, jackett pi-hole, transmission, plexpy
Alright thanks!
I think I will go for a DS918+ and a 10TB drive to start with, it seems like a very popular NAS too.
Apparently you can upgrade the RAM to 16GB too even if it’s not officially supported too, not sure if that’s required though.
I dont understand this comment - the 1019+ is only $649.99 while the 1819+ is $949.99 – so that is the $300 price difference you’re complaining about between the 918+ and 1019+ Definitely not “around” the same money, but yes you get more bays.
FYI, I do own a DS1819+ and use it as a Plex Media Server, with the transcode options. Having a really good connection (at least 30MB/s… download & upload), I direct play as much as often. (Before that, I used a DS415play and it couldn’t transcode properly… so I knew I wouldn’t miss a QSV to transcode. That being said, I do not use 4K content and don’t wish to stream 4K from outside home.)
That being said, I tested my DS1819+ and it perfectly transcode 1080p / 20Mb/s videos. I guess it won’t do as good as a 918+ (which allows to transcode several streams)… but it does the job. If need be, I can test with several streams at the same time and see how the CPU handles it. (Not sure it will work but it might handle two streams.)
I have a question about DS1019+ transcoding. In this thread, it mentions 4k to 1080p, but what about transcoding to all other resolutions?
I bought the DS1019+ after reading/watching lots of positive reviews and have been generally impressed. I do, however, have some buffering issues (at all sorts of resolutions) when trying to watch “This Old House” recordings (made by HDHomerun) on the web client. HW transcoding is turned on (double-checked before posting!).
The identical recording on the Nvidia Shield TV (my previous Plex Media Server) plays at 1080 with no buffering.
Thanks for the info. I do believe you are correct about the interlace.
But…
The NAS reports about 35% CPU during playback. You would think there’s a little more grunt left in the machine.
So it probably is not a good idea to switch HDHomerun’s DVR engine to the DS1019+ as I’d just have all sorts of issues getting an uninterrupted picture to the screen?
