DS415+ Installed DSM 6.2-23739 Update 2 today 7/21/218. Now Plex will not start. What is the issue. IS Plex going to place an update tthat will work on this update?
Did this work? I’m having the same problem. DS716+II here. Tried to revert to previous version of DSM but unable to do so after Update 2.
Yes, I had to uninstall the current version and install the 64 bit version. I had to download the 64 bit version directly from Plex and do a manual install. Synology only has the 32 bit version.
Yes, me too. Worked! Thanks.
