Synology Error Processing Recording - DVR:Grabber: Failed to inspect file
I’ve been having Scheduled recordings get all the way through a show then vanish, this is all I can find in the logs. Any help would be great
May 08, 2019 20:52:10.712 [5548] WARN - DVR:Subscription: No container available for /tv.plex.providers.epg.onconnect:3/metadata/com%2Egracenote%2Eonconnect%3A%2F%2Fshow%2F14154433
May 08, 2019 20:52:12.192 [8608] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03250.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 20:52:54.121 [8608] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03292.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 20:55:03.158 [6720] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03421.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 20:55:57.969 [8608] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03476.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 20:56:23.027 [12712] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03501.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 20:56:48.200 [12712] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03526.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 20:57:16.217 [2896] ERROR - EventSource: Retrying in 600 seconds.
May 08, 2019 20:57:45.061 [12712] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03583.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 20:58:05.085 [6720] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03603.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 20:58:27.152 [6720] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03625.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 20:59:42.173 [6720] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03700.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 21:00:20.064 [6720] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03738.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 21:01:14.085 [12712] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03792.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 21:01:49.961 [8608] ERROR - Caught exception trying to stream file: D:\temp\Transcode\Sessions\plex-transcode-e4ef1fdf-c254-47bb-a144-63ea4d13ce78\media-03828.ts: write: A request to send or receive data was disallowed because the socket had already been shut down in that direction with a previous shutdown call
May 08, 2019 21:02:01.547 [6596] ERROR - DVR:Grabber: Failed to inspect file: Could not parse \Server\media\Media\Recorded TV.grab\b03a89c39f46f27d30186b493186989e112064b9\The Amazing Race (2001) - S31E04 - Episode 4.ts (error=-2): No such file or directory
May 08, 2019 21:02:01.553 [8736] ERROR - DVR:Grabber: Error processing files: boost::filesystem::directory_iterator::construct: The system cannot find the path specified: "\Server\media\Media\Recorded TV.grab\b03a89c39f46f27d30186b493186989e112064b9"
I’ve had the near identical problem for quite a while now on my Synology Plex server. Receive the same error though the string after the .grab\ is different. This have something to do with temporary files? Plex has full permissions to all of these directories so I’m not sure whats happening.
Synology for me as well, all rights are fine, been wondering if it’s a file size issue or something, I can watch as the .ts file grows as the recording goes on then at some point about 45min in the .ts file vanishes, plex still says it’s recording, gets all the way to the end and then cant transcode the .ts file because it’s gone.
