Hey,
I’ve got a well-running PMS on Synology DS1019+ and things work fine. However I’d like to enhance it a bit more.
My Synology responds to my custom domain (let’s say synology.example.com) and I’m generating a Let’s Encrypt certificate for it through Synology interface.
I would like to use that certificate with Plex as well for situations where I don’t want to go through plex.tv for whatever reason.
I’ve seen some guides on how I could manually export a certificate and then import it into Plex. But the problem is that these certificates renew every couple of months. And I definitely don’t want to be bothered to repeat the process with such frequency and at the same time worry that I’ll forget and have the whole thing unavailable as a result.
I’ve seen that someone on QNAP side actually produced a scripted solution for the same thing. However I’m unfortunately not savvy enough to replicate the process for Synology. Is there anyone who has enough skills in this area to do this?
Thanks,
Vlayke
