Synology vs NUC?
I was running Plex on my Synology 918+ which does support hardware transcoding. To get more storage, I switched to an 1819+ before learning they no longer support hardware transcoding. Womp womp to me.
A buddy recommended I switch to hosting it on a dedicated NUC running Ubuntu - so I’ve just picked up a new i5 10th gen NUC, put memory and an SSD in it and before I start installing anything, I realized … I don’t know if it’ll support hardware transcoding either.
I typically have a couple of direct plays going on, and as many as 6 remote / off site transcoded plays going too (family in the UK and Germany are quite heavy users).
Am I well specced, or should I get a different NUC?
Do you have room for both?
You can mount the one NAS to the other and let the DS918+ do the transcoding.
It’s a NUC10FNK
I don’t get any transcoding when playing locally - but almost all my remote sessions are transcoded, almost certainly due to bandwidth / local client configurations.
The 918+ got repurposed once the 1819+ was deployed, so I don’t have it for Plex any longer.
Huh. That doesn’t sound like a lot - I’ve had more than that on the 1819+ and the goal of this project was to increase the capacity of my Plex server a bit.
I may need to rethink.
what’s the full NUC spec please?
NUC10FNK doesn’t specify CPU. It should be NUC10IxFNK where x is the cpu.
It only tells us the case, board, and family.
sorry. missed that
Yep, it’s an i5. The supplied model number is the only one on the box, my bad.
The ASIC in that beast will crank some serious video transcoding if required.
The i5 will handle 4-5 Dolby 7.1 -> stereo audio conversions simultaneously with crunching down the video.
If the NUC is the Plex server, and media storage is on the NAS at 1 GbE, it’s golden.
The internal SSD will be perfect for the PMS database and general OS operation.
Where it’ll get touchy is if/when subtitles are involved. 6482 passmarks will, depending on type, allow some subtitle burning but it will be YMMV.
Best case here is Text-based subtitles (SRT), which the player supports and overlays by itself.
In this case:
  1. UHD -> 720p
  2. 7.1 -> stereo
  3. SRT subtitles transmitted as the 3rd stream (player doing the rendering itself)
The NUC will cruise right along. I can see 4+ concurrent sessions out of that.
(I have a NUC8i7HVK here. I ran out of playback devices before I ran out of gas in the box)
Thanks - thats reassuring. Like I said, I can have 4 or 5 or so remote transcodes going, along with one or two local direct playbacks. Goal is the NUC running PMS, the media sitting on the 1819+ (the 918+ is out of the picture now, unfortunately).
From a network perspective, you’ll start running out of network at 10 concurrent DirectPlay streams of 80 Mbps each. (800 Mbps usage).
Direct is rarely going to be an issue - 2 max. There’s only 3 of us in the house, and one of them is a Youtube obsessed 11yo
