The A-Z sort on a library down the very right hand side of the screen
Hi
This is probably a very dumb question and no doubt easy to fix but I cant find the solution
The A-Z and A-Z ordering that appears on a library on the very right hand side of the screen.
I have managed to reverse it so it shows Z-A
I have tried editing the library to change the sort order to all the options (Library Default, Oldest, newest, name) but its not doing anything different (other than rescan the whole library every time)
ANy help gratefully received
PLease can someone point out what dumb thing I have done
If you click on Title in the dropdown it should change the sort order (from an Up arrow to a Down arrow or Down to Up.) :wink:
sort_order
Thank you.
That fixed it.
