Server Version#: 4.44.2
How do I rearrange the listing order of libraries in the PLEX sidebar? In my PINNED section I click on (…) and select reorder, but when I try this method in the MORE section, I do not get the REORDER option.
What order is it listed in under each server? It seems like alphabetical would make sense, but it’s definitely not in that order.
That it is currently un-sorted, is a bug.
It will be
Library type > library title
This applies only to the order when you set your side bar to the MORE view mode.
The order of “pinned” libraries is still custom.
thanks for acknowledging this. was going crazy wondering why the sort was all out of wack.
Thanks @OttoKerner ! I figured it was a bug.
@trumpy81 Well, to me, it does make a difference, because I have a list of oddball libraries that I don’t usually put on the main page, but I sometimes like to browse through.
My apologies to trumpy81, OttoKerner, tikilab, and mophwawka for your responses. I don’t know what suddenly cobbled up PLEX for me, but I have been working to straighten it all out. I simply lost track that my original post was still active. I have things straightened out now. Please mark this string as “solved.”
