The client supports direct domain connection
I found that when using the client to watch,It is always easy to freeze and buffer。
I think this is because the client and server are transferred through Plex.
I found that the client now only supports direct IP connection。
But my public IP will change at any time。
I have a fixed domain name。
It would be great if the client can directly connect to the server through the domain name
我发现用客户端看的时候,总是很容易卡死和缓冲。
我想这是因为客户端和服务端是通过Plex传输的。
我发现客户端现在只支持IP直连。
但是我的公网IP随时会变。
我有一个固定的域名。
如果客户端可以通过域名直接连接到服务器就好了
You should already be able to specify Custom server access URLs in Settings > [Server Name] > Network.
See: Network | Plex Support
Is it on the ios client? I didn`t found it, No [Server Name] in [Settings], Just[advanced
] in it. Settings > Advanced > Network > Server Connections > Add Connection, It just supports direct IP connection.
It’s a configuration on your server
So the iOS client cannot connect directly through the domain name, right? Can you support this in the future?
There’s been a separate feature suggestion discussing exactly that. Concluding you can already configure Plex to connect remotely through a custom server access URL – that case should not require another manual connection entry in your client.
If I access the server through a custom URL, does the iOS client also directly connect to my server?
I’m not using this feature myself so I cannot verify it for you. From what I’ve been reading, it should be working that way.
Thank you very much
