I have Plex installed on Win7. Unzipped and renamed as usual. The NRK icon is showing under channels. Entering this channel, I get TV / Radio / Podcast. In TV, I choose "Direkte TV", here I see NRK1+2+3. On all 3 of them I get
This channel is currently unavailable.
One time I got the Plex page with the orange play button, but after hitting the play button I got the same message. I have this problem both local and from a different computer on the network. (web client). Not sure where to start looking for a solution. Any suggestions?
Thx. Just checked out the github issue page. Looking forward to your updates. This is somehow one of the missing link in becoming a cordcutter ;o). And the advantage of course to have it streamed to all devices, incl. TV. Will you post an update on this forum when a solution is found?
Yeeeeeeh !! looks like all is working now. I haven't changed anything in my setup. Works really well. Even the search from the main Plex web page is scanning NRK for relevant information. Super! Great work, thx a 1000 :)
This is all because of mr. burnbay, all cred to him.
Guys and girls, can you test the latest version thoroughly on as many setups as possible and either respond here or (preferably) create github issues for problems you find (with logs and good explanations on the setup and how to reproduce)?
We are preparing to submit it to the Plex app store and would like to nail out the biggest bugs.
@miceagol How did you install, reinstall and restart the NRK channel? And please try to find and post relevant logs of what happens in the background when it fails when you try to go into the channel.
I installed the app first time from Plex Home Theater. The second time I did this through plex.tv. There I clicked on Channels, then hovered the mouse above the NRK app and clicked the uninstall button. I installed the app again by clicking the "Install Channels" button in the top right corner. I then browsed to the NRK app, installed it, and then updated, restarted and reset the app from the same menu.
