Seems to work great, but radio doesn’t work. Unable to cast. Same with podcast.
This seams broke again
"Cannot load M3U8: 404 not found"
I believe @burnbay have fixed this, I've asked the Plex guys to update the plugin in the Channel Directory, should auto update once done.
i grabed the github
https://github.com/eithe/NRKTV.bundle
nada :(
Logs?
Logs , i don't see anything nrk related in logs that is taged with error
I get the same error unfortunately. And as far as I can see, Plex does not generate any messages in the log regarding the failed connection.
@eithe said:
Night wrote on June 20 2015, 6:47 PM: »This seams broke again
“Cannot load M3U8: 404 not found”
I believe burnbay have fixed this, I’ve asked the Plex guys to update the plugin in the Channel Directory, should auto update once done.
Hei, I grabed NRK from github, not plex store, and still broken
here is log from that plugin
2015-08-23 14:20:23,569 (7f30d582d740) : INFO (core:347) - Starting framework core - Version: 2.6.2, Build: 9c43436 (Mon Jul 20 02:39:32 UTC 2015)
2015-08-23 14:20:23,569 (7f30d582d740) : DEBUG (core:359) - Using the standard policy
2015-08-23 14:20:23,570 (7f30d582d740) : DEBUG (core:448) - Starting runtime component.
2015-08-23 14:20:23,698 (7f30d582d740) : DEBUG (core:448) - Starting caching component.
2015-08-23 14:20:23,699 (7f30d582d740) : DEBUG (core:448) - Starting data component.
2015-08-23 14:20:23,699 (7f30d582d740) : DEBUG (core:448) - Starting networking component.
2015-08-23 14:20:23,793 (7f30d582d740) : DEBUG (networking:288) - Loaded HTTP cookies
2015-08-23 14:20:23,858 (7f30d582d740) : DEBUG (networking:458) - Setting the default network timeout to 20.0
2015-08-23 14:20:23,859 (7f30d582d740) : DEBUG (core:448) - Starting localization component.
2015-08-23 14:20:23,859 (7f30d582d740) : INFO (localization:408) - Setting the default locale to en-us
2015-08-23 14:20:23,919 (7f30d582d740) : DEBUG (localization:426) - Loaded en strings
2015-08-23 14:20:23,920 (7f30d582d740) : DEBUG (core:448) - Starting messaging component.
2015-08-23 14:20:23,932 (7f30d582d740) : DEBUG (core:448) - Starting debugging component.
2015-08-23 14:20:23,933 (7f30d582d740) : DEBUG (core:448) - Starting services component.
2015-08-23 14:20:23,933 (7f30d582d740) : DEBUG (core:448) - Starting myplex component.
2015-08-23 14:20:23,933 (7f30d582d740) : DEBUG (core:448) - Starting notifications component.
2015-08-23 14:20:23,962 (7f30bd7fa700) : DEBUG (networking:172) - Requesting ‘http://127.0.0.1:32400/system/messaging/clear_events/com.plexapp.plugins.nrk’
2015-08-23 14:20:24,277 (7f30d582d740) : DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.plugins.nrk in namespace ‘metadata’
2015-08-23 14:20:24,289 (7f30d582d740) : DEBUG (networking:172) - Requesting ‘http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes’
2015-08-23 14:20:24,607 (7f30d582d740) : DEBUG (runtime:1111) - Created a thread named ‘load_all_services’
2015-08-23 14:20:24,610 (7f30bd7fa700) : DEBUG (services:265) - Plug-in is not daemonized - loading services from system
2015-08-23 14:20:24,611 (7f30bd7fa700) : DEBUG (networking:172) - Requesting ‘http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_’
2015-08-23 14:20:24,646 (7f30d582d740) : DEBUG (runtime:1111) - Created a thread named ‘get_server_info’
2015-08-23 14:20:24,647 (7f30d582d740) : DEBUG (core:150) - Finished starting framework core
2015-08-23 14:20:24,647 (7f30d582d740) : DEBUG (core:558) - Loading plug-in code
2015-08-23 14:20:24,670 (7f309ffff700) : DEBUG (networking:172) - Requesting ‘http://127.0.0.1:32400’
2015-08-23 14:20:24,693 (7f309ffff700) : DEBUG (core:536) - Machine identifier is cbb7fca1e60b3468063ef0c3a296b417f13e1ff9
2015-08-23 14:20:24,693 (7f309ffff700) : DEBUG (core:537) - Server version is 0.9.12.8.1362-4601e39
2015-08-23 14:20:25,097 (7f30d582d740) : DEBUG (core:564) - Finished loading plug-in code
2015-08-23 14:20:25,531 (7f30d582d740) : DEBUG (runtime:640) - Adding a prefix handler for ‘NRK’ (‘/video/nrktv’)
2015-08-23 14:20:25,585 (7f30d582d740) : INFO (core:609) - Started plug-in
2015-08-23 14:20:25,585 (7f30d582d740) : DEBUG (socketinterface:160) - Starting socket server
2015-08-23 14:20:25,607 (7f30d582d740) : DEBUG (runtime:1111) - Created a thread named ‘start’
2015-08-23 14:20:25,607 (7f30d582d740) : INFO (socketinterface:184) - Socket server started on port 53047
2015-08-23 14:20:25,607 (7f30d582d740) : INFO (pipeinterface:25) - Entering run loop
2015-08-23 14:20:25,607 (7f30d582d740) : DEBUG (runtime:717) - Handling request GET /:/prefixes
2015-08-23 14:20:25,609 (7f30d582d740) : DEBUG (runtime:814) - Found route matching /:/prefixes
2015-08-23 14:20:26,132 (7f30bd7fa700) : DEBUG (services:362) - Loaded services
2015-08-23 14:20:26,178 (7f30bcff9700) : DEBUG (services:438) - No shared code to load
2015-08-23 14:20:29,256 (7f30d582d740) : DEBUG (runtime:918) - Response: [200] MediaContainer, 420 bytes
2015-08-23 14:20:29,399 (7f30bcff9700) : DEBUG (runtime:717) - Handling request GET /video/nrktv
2015-08-23 14:20:29,428 (7f30bcff9700) : DEBUG (runtime:814) - Found route matching /video/nrktv
2015-08-23 14:20:29,438 (7f30bcff9700) : DEBUG (base:117) - Checking if com.plexapp.plugins.nrk is broken
2015-08-23 14:20:29,448 (7f30bcff9700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMjMKY29tLnBsZXhhcHA$
2015-08-23 14:20:29,799 (7f30bcff9700) : DEBUG (runtime:106) - Sending packed state data (104 bytes)
2015-08-23 14:20:29,800 (7f30bcff9700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 961 bytes
2015-08-23 14:20:36,322 (7f30bcff9700) : DEBUG (runtime:717) - Handling request GET /video/nrktv
2015-08-23 14:20:36,334 (7f30bcff9700) : DEBUG (runtime:814) - Found route matching /video/nrktv
2015-08-23 14:20:36,343 (7f30bcff9700) : DEBUG (base:117) - Checking if com.plexapp.plugins.nrk is broken
2015-08-23 14:20:36,344 (7f30bcff9700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMjMKY29tLnBsZXhhcHA$
2015-08-23 14:20:36,530 (7f30bcff9700) : DEBUG (runtime:106) - Sending packed state data (104 bytes)
2015-08-23 14:20:36,530 (7f30bcff9700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 961 bytes
2015-08-23 14:20:36,976 (7f30bcff9700) : DEBUG (runtime:717) - Handling request GET /video/nrktv/tv
2015-08-23 14:20:36,978 (7f30bcff9700) : DEBUG (runtime:814) - Found route matching /video/nrktv/tv
2015-08-23 14:20:37,007 (7f30bcff9700) : DEBUG (runtime:106) - Sending packed state data (104 bytes)
2015-08-23 14:20:37,008 (7f30bcff9700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 1747 bytes
2015-08-23 14:20:39,421 (7f30bcff9700) : DEBUG (runtime:717) - Handling request GET /video/nrktv
2015-08-23 14:20:39,423 (7f30bcff9700) : DEBUG (runtime:814) - Found route matching /video/nrktv
2015-08-23 14:20:39,424 (7f30bcff9700) : DEBUG (base:117) - Checking if com.plexapp.plugins.nrk is broken
2015-08-23 14:20:39,425 (7f30bcff9700) : DEBUG (networking:172) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X1N0b3JlU2VydmljZTpJc0NoYW5uZWxCcm9rZW4_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMQpzMjMKY29tLnBsZXhhcHA$
2015-08-23 14:20:39,442 (7f30bcff9700) : DEBUG (runtime:106) - Sending packed state data (104 bytes)
2015-08-23 14:20:39,443 (7f30bcff9700) : DEBUG (runtime:918) - Response: [200] MediaContainer, 961 bytes
2015-08-23 14:20:39,848 (7f30bcff9700) : DEBUG (runtime:717) - Handling request GET /video/nrktv/live
2015-08-23 14:20:39,851 (7f30bcff9700) : DEBUG (runtime:814) - Found route matching /video/nrktv/live
2015-08-23 14:20:39,854 (7f30bcff9700) : DEBUG (services:616) - Found a service matching ‘Direkte NRK1 - NRK TV’ - NRK-Live (com.plexapp.plugins.nrk)
2015-08-23 14:20:39,854 (7f30bcff9700) : DEBUG (services:41) - Loading service code for NRK-Live (URLServiceRecord)
2015-08-23 14:20:40,019 (7f30bcff9700) : DEBUG (services:41) - Loading service code for Fallback (URLServiceRecord)
2015-08-23 14:20:40,357 (7f30bcff9700) : DEBUG (services:616) - Found a service matching ‘Direkte NRK1 - NRK TV’ - NRK-Live (com.plexapp.plugins.nrk)
2015-08-23 14:20:40,359 (7f30bcff9700) : DEBUG (services:616) - Found a service matching ‘Direkte NRK1 - NRK TV’ - NRK-Live (com.plexapp.plugins.nrk)
2015-08-23 14:20:40,361 (7f30bcff9700) : WARNING (objectkit:208) - Media part has no streams - attempting to synthesize
2015-08-23 14:20:40,373 (7f30bcff9700) : DEBUG (services:616) - Found a service matching ‘Direkte NRK2 - NRK TV’ - NRK-Live (com.plexapp.plugins.nrk)
2015-08-23 14:20:40,377 (7f30bcff9700) : DEBUG (services:616) - Found a service matching ‘Direkte NRK2 - NRK TV’ - NRK-Live (com.plexapp.plugins.nrk)
Any news about the NRK plugin. I have the same problem as already mentioned.
Hi, guys, those that have the “Cannot load M3U8: 404 not found” problems, what OS and version are you on?
Hi
I get “Cannot load M3U8: 404 not found” when using firefox.
I get “aes decryption not supported in premium edition” when using chrome
I have PLEX server on Windows 10. Cient on Windows 10. Plex 09.12.18
@dioden said:
Hi
Tested some more, it is OK when using edge browser.
It fail if i cast to Chromecast
Dioden
Ok, thanks, not sure about this one - I don’t use the web client personally, but I just tested now and I also get the m3u8 error in Chrome with my mac PMS.
Still same error.
Plex server 0.9.12.18 on Ubuntu 14.04.3 LTS (trusty) using Chrome 47.0.2526.73 on Windows 7.
Edit: Upgraded to Plex server 0.9.12.19, same error.
This is the XML-info from Plex:
MediaContainer size=“1” identifier=“com.plexapp.system” mediaTagPrefix="/system/bundle/media/flags/"
Video url=“http://tv.nrk.no/direkte/nrk1” sourceIcon=“http://resources-cdn.plexapp.com/image/source/com.plexapp.plugins.nrk.jpg?h=43a9f64” key="/system/services/url/lookup?url=http%3A%2F%2Ftv.nrk.no%2Fdirekte%2Fnrk1" type=“clip” title=“NRK 1” summary=“Bredt og variert programtilbud. Norges største tv-kanal.” sourceTitle=“NRK-Live” art=“http://resources-cdn.plexapp.com/image/art/com.plexapp.plugins.nrk.jpg?h=b67941f” ratingKey=“http://tv.nrk.no/direkte/nrk1”
Media audioChannels=“2” protocol=“hls” optimizedForStreaming=“1” height=“720” width=“1280” container=“mpegts” audioCodec=“aac” videoCodec=“h264” videoResolution=“720”
Part container=“mpegts” key="/:/plugins/com.plexapp.system/serviceFunction/url/com.plexapp.plugins.nrk/NRK-Live/PlayVideo.m3u8?args=Y2VyZWFsMQoxCnR1cGxlCjAKcjAK&kwargs=Y2VyZWFsMQoxCmRpY3QKMQpzNApucmsxczgKdmlkZW9faWRyMAo" file="" optimizedForStreaming=“1”_
Stream index=“0” selected=“1” streamType=“1” height=“720” width=“1280” codec=“h264” id=“1”/
Stream index=“1” selected=“1” streamType=“2” channels=“2” codec=“aac” id=“2”/
/Part
/Media
/Video
/MediaContainer
Is this plugin still being maintained, or is there a better alternative ?
