[NRK Nett-TV](http://www.nrk.no/nett-tv/)
Hva med å prøve et forumsøk?
Den ligger her: http://github.com/jonklo/plex-nrk/downloads
Takk!
Jeg gjorde et søk i App store der den burde vært. [Flott hvis utvikleren sender den dit.](http://forums.plexapp.com/index.php?/topic/11745-how-to-get-your-plug-in-in-the-app-store/)
I submitted it for app store review some time ago, follow the progress here:
https://plexapp.lighthouseapp.com/projects/31804-plex-plug-ins/tickets/601-new-plugin-nrk
Looking forward to having it in the app store myself
Hi, great work, but i have problems opening streams from your plugin, i'm using plex v9
Can you browse through the shows, or is it just the clips that doesn’t work? Is the screen blank or do you get a popup box with an error message?
Could you please open an issue with more information over at GitHub?
http://github.com/jonklo/plex-nrk/issues
Thanks!
I am married to a Norwegian so I thought I’d load this one up. I can browse the shows just fine, but I just get the loading disk and no video. I let it load for a good 5 minutes just to sure.
Takk for hjelpe!
Maybe it only works for .no IP adresses. The plugin works great for me.
That is what I thought until I went to the site with firefox and was able to watch videos.
